anyone had any type of problem w/alignment after Eibach spring install w/OEM shock??
Location: Houston,TX-moving to The Woodlands,TX SOON!!!
Toyota Tacoma & Lexus IS250
I can get a set for $230 shipped...just don't want any alignment probs.
I'm assuming the Coupe and Sedan are very similar so it doesn't make any difference which car here...
thanks in advance !!
C240/6 Megma Red
My Sedan have only toe adjustment front and rear. I have them print out before and after alignment. I have H&R spring, the front is almost out of spec -0.5L, -0.6R spec is -0.63 max. The rear is a little out -1.7L, -2.0R spec is -1.56. I'm using thin rubber spacer in the rear. I'll change that to the thicker pad hopefully bring the rear camber back closer to spec.
Right Left
before after before after spec
F Camber -0.6 -0.6 -0.5 -0.5 -.27 +- 0.36
F Caster 11.0 11.0 10.7 10.7 10.18 +- 0.50
F Toe 0.03 0.17 0.02 0.17 0.17 +- 0.08
R Camber -1.8 -2.0 -1.6 -1.7 -1.06 +- 0.50
R Toe 0.35 0.22 0.28 0.22 0.27 +- 0.06
Right Left
Wouldn't the old trick of grinding a little adjustment room out of the shock mounts work here?
Done that on struts before to adjust the back (on another car) then just need to find someone competant to align it.
2002 C230 : 2007 C230
bumping this up again..
wanted to see if everyone gets the longer camber bolts for the front or if some just align it as close as possible....
also if I get the bolts at MB, I just hand them over to the alignment shop and tell them "here, you might need these to get the alignment to within spec"....?
The True OG Modded out W203
I didn't get the longer camber bolts. I had my car aligned 2 weeks after installing my springs. Everything seems ok w/the tires, I had a tire guy check them last week. But then again, I've only had the car dropped for about 3 months...Good luck.
