Reinstalling the Center Arm Rest
Thanks...
I don't know if it's the same center arm rest mechanism, buuut here's what I did to get mine back on.
Look at the underside of the armrest where it would connect.
There should be those arms that are... spring tensioned I guess that would clip onto the center box that you now have open right?
So put one side back on, then try and close it.
It won't close. So, stick your finger into the unclosed side that won't fit and push the spring clip up. Yeah, I'm reading this and it's not really clear.
After pushing up, do this next step REALLY QUICK to avoid smashing your finger...
Pull out and push down at the same time.
If you're lucky it'll snap on and it's fixed.
If you're unlucky it'll hurt a little bit >_>
But basically, you want to
1) Place one side on as well as you can onto the clips
2) Close it
3) Stick your finger into the side that can't close properly
4) Push the clip up on the side that can't close
5) Pull out of the slot and push down on that block
6) .....
7) Sucess.
2) Close it
6) .....
7) Sucess.
Just to add to this:
Each side of the arm rest has a clip. Under the clip you will notice there is a gray pin. The pin sticks out and goes in depending on if you are pressing the latch on the side of the top of the arm rest. There is also a pin close to the front of the arm rest top that also goes in/out when you press the latch.
To install the arm rest, it is much easier if you are pressing in the latch on the side you are trying to put on. The pins go inside corresponding holes on the arm rest body.
Once you put on one side, press down the latch as hard as you can on the other side, press in the spring-loaded clip, and press down on the arm rest.
I used some force to do it and it went into place after a number of tries.
Make sure you have not broken any of the holes in which the pins go into. I noticed damage on one, which is why the arm rest cover likely came off. If you have broken or damaged one side or one corner, you may have more difficulty.
Car done on: 2004 C230K
Nice to see a newbie putting something back into the forum - Good for you!
