just installed r1concepts brakes
Old Feb 28, 2009 | 04:21 AM
paypaboi's Avatar
03 W203, 13 E350, 13 W204, 14 C218
Hey MaeCclass! i hope you didn't put new tires on! I know why your tire looks like that!!!!! i just did it to my two front tires today when I lowered my car!!! your tire is rubbing against the coilover like the bottom of the spring thats exactly what my two front tires looks like now...
Old Feb 28, 2009 | 04:59 AM
Mu9enx's Avatar
01' C32o
wonder if they have c32 rotors.. hmmm
Old Feb 28, 2009 | 01:56 PM
paypaboi's Avatar
yes..www.r1concepts.com they don't have oem ones but they have theirs that they make that fit the c32 but they only come in premium not eline. premiums are bomb tho. look like a BBK rotor too really agressive.
Old Mar 19, 2009 | 05:51 PM
ROLLNNN's Avatar
2005 CLK320 Vert & 2005 CLK55 AMG
Originally Posted by maecclass
just did my front and rear rotors and posiquiet pads and im happy with it. found my front driver side tire cracked half of the tire. brakes feel the same as stock with less dust.got the brakes from paypaboi gave me a good deal on the brakes, also just installed my toyos proxy 4 and did service b. But decided to run on stock wheels never really driven the car stock cause lowered and put on the wheels when the car only had 48 miles. Now car is running smooth no vibrations in front wheels.
After having the R1Concepts rotors for over a month now, what do you think about them?? You have the Eline correct?? I might just go with R1's but was looking into the premium. Anyone have the premium rotors or know the difference between premium and eline??
Thanks.
Old Mar 20, 2009 | 05:04 PM
maecclass's Avatar
2005 C230 K and 2009 Smart
Thanks.
yes i do have the eline rotors and they work good. i havent wash my car to see how much dust the pad would give, and suprisingly looks that same as when i put my brakes on. rotors are quiet no squeeks and pad on normal barking is fine but ion hard braking needs a little more pressure ill post pics of the wheels and brakes after a month
Old Mar 20, 2009 | 05:27 PM
ROLLNNN's Avatar
Thanks man! did you use the ceramic pads for front and rear?
Old Mar 21, 2009 | 12:11 AM
  #32
maecclass's Avatar
no i think they are the posi quiet semi-metalic
Old Mar 21, 2009 | 12:20 AM
  #33
maecclass's Avatar
Here are pics of my wheels and brakes after a month also haven't wash the car since i installed my brakes just to see how much dust will the new pads will give. Its is 95% less than oem. first 2 pics are rear wheels and still finger prints from the time installed my brakes.
Attached Thumbnails just installed r1concepts brakes-img_2725.jpg   just installed r1concepts brakes-img_2726.jpg   just installed r1concepts brakes-img_2727.jpg   just installed r1concepts brakes-img_2728.jpg
Old Apr 2, 2009 | 12:07 AM
  #34
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
so this didnt make sense when you guys first talked about what rotors come which way...on the website you can click any for any line...but you guys are saying for the E-line only drilled in front and drilled+slot in rear and for premiums its whatever for both front and rear? or are you saying that no matter what R1 only drills front rotors (even though they advertise otherwise) and can do drill+slot on rear?
Old Apr 2, 2009 | 06:56 PM
  #35
ChaRgeC230's Avatar
05 c230 SS
ive had mine on for about two months. and NO DUST AT ALL!!! love the pads!!
Old Apr 2, 2009 | 07:08 PM
  #36
ROLLNNN's Avatar
Are these the Centric posi-quiet semi-metallic pads??
Old Apr 2, 2009 | 08:25 PM
  #37
maverik259's Avatar
anyone know the answer to my question, geesh! haha
Old Apr 2, 2009 | 09:21 PM
  #38
Utahkompressor's Avatar
W124, W203, W204, W251
Does it provide better brake feel?
Old Apr 3, 2009 | 01:30 PM
  #39
ChaRgeC230's Avatar
05 c230 SS
brake feels the same.. n these are the semi metalic
Old Apr 4, 2009 | 05:40 AM
  #40
paypaboi's Avatar
Simply put it depends on the car. Some rotors can be drilled and slotted in the front that's why they advertise it that way because when they are building a huge database for u to search for car parts its easier to give everything the same option than to have different options for every different car. upon checkout they will inform you that you can't cross drill and slot if not possible. and the reason they can't slot has something to do with the slot getting too close to the veins of the rotor which would cause it to lose support and end up cracking.
Old Apr 4, 2009 | 04:55 PM
  #41
maverik259's Avatar
I've seen slotted on the c230 before, so how come they can't do it and others can? and does anyone know the weight comparison b/n oem front and rear and R1 Front and rear, rotors?
