'03 C320 auto trans. behavior ?
This is all fine and good, but when my car shifts from 3rd to 4th under moderate-to-heavy acceleration, the transmission sortof of "kicks-in" abruptly upon engaging the 4th gear. I hear the upper RPM range of 3rd, then the pause (state of neutral as described above), then it seems to stutter when hitting 4th. This stuttering sounds like engaging fourth, then backing off very briefly, thenly re-engaging. Almost as if I killed the throttle right when hitting fourth, then reapplied.
Does this make any sense? Has anyone experienced this kind of behavior? I'm trying to determine if this is normal or if I need to take it in for service. Note it does not do this with touch-shift, only the automatic "D" program in "S" mode.
On harder throtlle it shifts quicker because it figures that's what you want.
Definitely have noticed harder shifting when cold, but the issue I described happens when the engine is hot. I have driven a loaner C320 (2003) and did not notice this condition.
