Wagons Ho ! Let's see some W203 wagons.
Rating: Thread Rating: 5 votes, 5.00 average.
Old 09-28-2011, 07:49 PM
  #151
W203E35's Avatar
2006 C350 Sport 6MT
+1, what color is that? Never seen that color before. Looks real nice.
Old 09-28-2011, 08:51 PM
  #152
Super Moderator
Glyn M Ruck's Avatar
I think that is "Perlite Grey" metallic. Or at least that's what it's called in ROW. USA sometimes calls colours other things.
Old 09-28-2011, 11:10 PM
  #153
euromedic's Avatar
2002 C320 Wagon
That looks awesome! You can lift the rear a bit by installing a set of higher pads at the top of the springs. Did you use any spacers with the wheels?
Old 09-29-2011, 12:03 AM
  #154
mk4vr6gti's Avatar
c320 Wagon
I have 13mm of spacers in the front and 10mm ion the rear. I may goto 15mm in the rear though.
I have coilovers so im not running any spring pads. I'll just spin the fronts down a bit and the rears up a VERY little bit and I think it will sit perfect.
Thanks for responses......still more mods to do!
Old 09-29-2011, 01:35 PM
  #155
glocati's Avatar
2013 ML350
Sweet Wagon. Looks awesome. That is an awesome color. What color interior?? I also have H&R coilovers on my wagon. Just as you say, twist the fronts down, and it will sit perfect.
As a point of reference, here's crappy i phone pic of my wagon with the front c/o adjustment down to about 4 full threads left on the adjustment.
Old 09-29-2011, 03:10 PM
  #156
mk4vr6gti's Avatar
c320 Wagon
Your front is right where I want to be
I just started mine a little high and I'm working my way down that low.
My rears are about halfway on the threads, and I like where it's sitting, but I haven't had any extra weight in the back yet so it may have to come up a little bit. I bought the wagon for it's extra room (and because I like the look of wagons more then sedans) so I don't want to restrict the extra cargo space because the car it too low to carry anything.
The interior is light gray and its a pain in the butt to keep clean with a 90lb Black Lab in the car all the time. Mud from his paws and black hair COVERS the inside of my car!
Old 09-29-2011, 03:11 PM
  #157
Midnight Koop's Avatar
CL203
love it... is that miro111's?
looks sick!
Old 09-29-2011, 03:17 PM
  #158
mk4vr6gti's Avatar
c320 Wagon
looks sick!
Thanks....!!!!
and Yes...Miro 111's....18x8.5 front and 18x9.5 rear.
I replaced the center caps with 2011 ML caps since they're the only 65mm's I could find and the standard Mercedes size seems to be 70mm. The wheels look 1000 times better since I changed them.
Old 09-29-2011, 03:22 PM
  #159
CL203
Here's mine.......
I just put H&R Coilovers on it this past wekeend. Unless it settles more, the front will need to come down about a half inch and the rear may need to come up just a bit.
your height looks a lot like mine and i'm on H&R too... do you remember how many threads you had left in the rear?
i'm puzzled because i only have about 1-2 left from max height and i'm pretty tucked in the back.
love the wagon..
one suggestion... did you ever think about vinyl wrapping your window trim to mask the fade?
Old 09-29-2011, 05:27 PM
  #160
glocati's Avatar
2013 ML350
Cool. yea, it's hard to get it just right height wise right out of the box. A few teaks and you will get it dialed in. the good news is the fronts are easy to get to and adjust..Rears are kind of a *****...
I have hauled a pretty few heavy loads and it can take it well. I had a dozen heavy concrete pier pads and bags of cement in the back of mine and although a bit slammed, handled it fine with no rubbing. That was when i had 9.5 " wheels in back too.
Anyhow, cool wagon !
Old 09-30-2011, 03:18 PM
  #161
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
Thats a baddass wagon!
Old 10-04-2011, 11:18 AM
  #162
mk4vr6gti's Avatar
c320 Wagon
So now I want to replace rotors and calipers since the suspension and wheels are done.
Any recomendations for the wagons?
Since it's a a little heavier car.....more weight over the rear wheels...?
Old 10-04-2011, 01:15 PM
  #163
CL203
not sure b/c i have my H&R's set evenly (actually a little higher in the back) and i have a similar spread with the rear tucked.
i'm currently trying to figure out how to fix it.
Old 10-04-2011, 02:31 PM
  #164
MBworld Guru
FrankW's Avatar
white and whiter
from more costly to less
you can do the Brembo GT (6 or 4 up front and 4 in the back) or slk55 setup with 6 piston up front and 4 in the back.
or
C32/55 setup with 4 up front and 2 in the back
or
05-07 sport setup.
Old 11-22-2011, 12:10 AM
  #165
euromedic's Avatar
2002 C320 Wagon
Old 11-22-2011, 12:17 AM
  #166
euromedic's Avatar
2002 C320 Wagon
It's been a frustrating time with the wagon, the last straw being that water got into the underhood fuse panel while it sat in the driveway for 2 weeks. It appears that the drain holes for the windshield wipers were plugged, causing water to seep into the box. Of course, it seemed that the seal wasn't doing its job either.
Long story short, it has been sent to pasture since the repair would have been astronomical. Thanks for sharing the knowledge, but in the end it is a premium automobile with all the strings attached to it. I've got this now:
What a hoot to drive, like a go-kart Have a Happy Thanksgiving
Old 11-22-2011, 12:45 AM
  #167
hanknum's Avatar
'02 C320 Wagon, '78 308 GTS, '06 Highlander Hybrid
Sorry to hear Euro...I sent you a PM.
Old 11-22-2011, 02:08 AM
  #168
glocati's Avatar
2013 ML350
[QUOTE=euromedic;4928035
What a hoot to drive, like a go-kart Have a Happy Thanksgiving [/QUOTE]
Peter...o man, sorry to hear. Congrats on the new ride and all the best to you. Hopefully you'll check in every now and then. Greg
Old 11-22-2011, 09:52 PM
  #169
Super Moderator
samaritrey's Avatar
THE C350
This makes me sad a beautiful white wagon gone
Old 12-04-2011, 09:09 AM
  #170
anonymousmoose's Avatar
Audi A4 Quattro 2013
I never thought I'd like wagons but the pics here are changing my mind (still prefer the sedan).
I also found my car with the AMG kit in wagon form;
Old 04-16-2012, 12:44 AM
  #171
glocati's Avatar
2013 ML350
quick pic of the wagon with new wheels
Attached Thumbnails Wagons Ho !  Let's see some W203 wagons.-benz-001.jpg   Wagons Ho !  Let's see some W203 wagons.-benz-014.jpg
Old 04-16-2012, 03:22 AM
  #172
Moderator Alumni
TruTaing's Avatar
w203 m112
Bigger pix damnit :P They're darker than I imagined. They almost a blue-ish tint on one of those pix too!
Old 04-16-2012, 10:06 AM
  #173
Super Moderator
Looks good Greg!
Old 04-16-2012, 10:33 PM
  #174
glocati's Avatar
2013 ML350
Thanks Glyn and John ! Yea, John, need to snap better pics for sure. These were real quick in the driveway and came out dark. You are right in that certain light there is a slight blue tint to them.
I just got some different center caps, so will try and get some better pics soon.
Cheers, Greg
Old 04-16-2012, 10:53 PM
  #175
MBworld Guru
FrankW's Avatar
white and whiter
looking good grego!
what happened to your last set?
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
Quick Reply: Wagons Ho ! Let's see some W203 wagons.
