Flat Badge
Help! Do I have the correct part? I ordered from expresparts off ebay. The description said...W124/W203/W204/W208/W209/W210/W211/W215/W219/W220/W221/R170/R171, etc. Basically, most Mercedes cars out. This is an original hood badge, not like other aftermarket replacement badges on eBay
The badge is larger than the original base on my C280. See pic. If I install this it will not be flush in the round groove on my hood.
AND... it's made out of plastic... Is this original OEM? The plastic bag is labeled with a tag from MB.
To my knowledge, there are only two sources for "flat badges" that actually sit in the hood recess. First, the "White Star" badges made by DFWDude and sold via the sticky thread at the top of the W203 page (and he has apparently got less than 8 left). Second, there is a seller on Ebay called MKM Customs. (I've attached a picture of that one.) They both start with the OEM hood star base part (that fits in the recess), and then fill in the center portion where the star assembly sits with a flat, Mercedes star.
These latter two are all metal construction with custom work done to fill in the center, so they are generally a lot more expensive than the plastic OEM sits-over-the-recess badge.
Do I slide the sleeves on the prongs of the badge and push the whole thing down? OR do I try my darnest and push in the sleeves into the base and then push in the badge? I'm afraid i'll brake off the two plastic prongs.
Thanks for all the help guys.
