Comman Screen
Old Jan 24, 2003 | 05:08 PM
Davidta's Avatar
C230 Kompressor SPORTS COUPE
Comman Screen
Does anyone that has command in a coupe have the screen in their dash displaying directions when command is active?
Old Jan 24, 2003 | 06:05 PM
Lynn's Avatar
You are supposed to be able to use the steering wheel buttons to display the nav instructions on the MFD. I see your COMAND is a retrofit. If you can't see the instructions on the MFD, you will need to have the dealer use the DAS to set the navigation to present. It is done in the same menu where the "no phone" screen can be turned off and the HID's are enabled.
Old Jan 24, 2003 | 06:28 PM
Davidta's Avatar
I tried to have my dealer do it, they spent like a half hour looking for the screen and said it didn't exist, thats is why I am asking if any coupe owners have it or is it onyl a sedan thing, if other coupe owners ahve it, maybe I need to print them out instructions of where to find it like I did the Xenon pressent.
Old Jan 24, 2003 | 09:38 PM
Lynn's Avatar
Control Units -> Info. and comms. -> ICM -> Control Unit Adaptations -> Version Coding -> Optional Equipment
Above is the flow chart throught the menus in the DAS computer. This was originally provided by Richard and verified by Kleemann on his DAS. When Buellwinkle first tried to have the "No Phone" message removed, the tech couldn't find the correct menus. It turned out the front SAM module in his car was bad. That could be a reason they can't find the screen in your car. Or not. Good Luck.
Old Jan 24, 2003 | 10:39 PM
Davidta's Avatar
Thank you for your help
