DIY Foglamp Replacement
I removed the plastic trim piece that is right underneath the lamps to gain access. It has three bolts (all in wheel well) and three plastic rivets(?). To remove the plastic rivets you need to remove the small center piece and then the whole rivet will come out. The center piece goes up the middle and expands the rivet, so it needs to come out before the main body piece will come out.
I wish you luck because it is so tight I think it is going to be a major pain. Good luck.
Please post back any helpful info you learn, because I have a cracked lens and I will be changing the passenger side unit soon.
