DIY: M271 Throttle Body Cleaning/Getting to and Replacing your TB
Old Mar 14, 2012 | 01:12 AM
lylefc's Avatar
2005 C230 Kompressor Sport
I used the diy and it worked great! Thank you!
I also found oil in the throttle body and cleaned it up. I have a sneaky feeling that this is from the vacuum hose recall that happened in 2004 or 2005.
I'm going to call the dealership tomorrow since I got this car used, and see if they did the recall for the vacuum hoses. That could be spitting oil.
If you want to do the same, the recall code is:
2008020002
I also accidentally pulled the foam coil from the front air intake, which seemed to unravel a little. Does anyone use a more reliable hose for this??
Old Oct 19, 2013 | 01:15 PM
livearoha's Avatar
’03 C230 Sport Coupe
Thank you for the great DIY, like others I found oil inside as well. It was very simple to clean.
Old Mar 4, 2014 | 04:32 PM
alexstaar's Avatar
2003 W203 C230K
What size/kind of screwdriver do I need to purchase to remove the 2 screws mentioned? It looks like a female torx. I am going to go out and buy a set so I can start doing some engine work myself. Thanks!
Old Apr 13, 2014 | 08:59 AM
2subway's Avatar
C230 2003
fix
Thanks for the write up. I cleaned my TB today and found that it was worth removing the entire throttle body to get the other side of it cleaned. It was much much dirtier than the front facing side of the TB. I too found some residual oil.
Old Aug 11, 2014 | 11:14 PM
onehighfocus's Avatar
2014 c250
It was a pain to find, but here is the O-ring gasket I see on my 2004 C230
Throttle Housing Gasket - Throttle Housing to Intake Manifold
I had originally tried to source it at the dealer but they gave me a flat fiber gasket as shown in the parts drawing item#5 p/n: 271 141 12 80
it wasn't until I pulled the throttle body off that I realized I was duped
Old Sep 15, 2014 | 02:17 AM
murat orhan's Avatar
2007 CLK 200K
Thank you for the detailed information. With your help I was able to remove and clean my TB. There was oil also in mine. If you want to clean your TB my advice is to remove the TB completely because the real dirty area is the rear side. You just need to remove 4 screws and the wiring plug which is very easy. Now, I wait for the new gasket from my parts store. #271 141 10 80
I need to mention that it was not needed at all to remove the 2 torx screws that are down below. The hose was flexible enough.
Now, I have plans to remove and clean the other TB that is located on the supercharger (that regulates the boost by directing the air through the SC or directly to the intake manifold). You can see it on onehighfocus's pics as #4. Also I think I will need that flat gasket that he mentioned, #5. It seems that I will not need to remove the whole SC but just the part #3.
Does any one know how to deal with it? Or is it worth cleaning?
Old Sep 17, 2014 | 01:50 PM
  #32
2007 CLK 200K
okay, here is my TB after cleaning.
Attached Thumbnails DIY: M271 Throttle Body Cleaning/Getting to and Replacing your TB-image.jpg
Old Sep 17, 2014 | 02:40 PM
  #33
cm60k's Avatar
Excellent job, looks like NEW..
did you clean it with carb. cleaner or throttle cleaner..?
ZAYED,,
Old Sep 18, 2014 | 02:12 AM
  #34
2007 CLK 200K
Some throttle cleaner and an old toothbrush did the job.
Old Sep 18, 2014 | 02:59 PM
  #35
PelicanParts.com's Avatar
SPONSOR
That TB is super-clean! Great job!
Mark/Pelican Parts
Old Dec 1, 2014 | 01:04 PM
  #36
joeguzman2001's Avatar
c230 Kompressor
Did you have to do an idle relearn?? I did this to my Altima and had to go through the idle relearn procedure. I want to this to my C230k but am worried about the idle getting messed up.
Old Dec 2, 2014 | 01:25 AM
  #37
2007 CLK 200K
No.
No idling issues after cleaning. Everthing worked as usual.
I did the same on my previous car, slk200k with M111 engine. Also there was no issues about idle relearn on that.
Old Nov 8, 2015 | 03:43 PM
  #38
PeteyV's Avatar
W203 C230, W210 E350, W166 ML63
I did the throttle body removal this morning. Everything went okay except when reattaching the hose. It would not go back onto the orange gasket over the TB. I tried everything, pressing down on the hose, maneuvering it, and nothing worked. I have done this before but for some reason it would not fit this time. The hose eventually came off of the second clamp that clamps onto the intercooler hose below so now I am stuck with the plastic tubing not attached to anything. I'm not sure what I should do now to try and get it back on because it is very awkward to get back on both ends.
Any suggestions?
Old Jul 10, 2016 | 01:01 AM
  #39
scottonfire's Avatar
2013 c250
those two hex screws SUCK. It's an e10 torx bit BUT the ****er doesn't come off w/ a regular ratchet. You need a vertical one cuz there's no room. I tried. I even removed the windshield wiper plastic hose to no avail.
Old Apr 3, 2026 | 03:44 PM
  #40
mikekilo's Avatar
W203 C180K 2003
IS there a trick to put the hose back on the TB? Somehow it doesn't seem to fit any more. CHeers!
Old Apr 3, 2026 | 03:45 PM
  #41
mikekilo's Avatar
W203 C180K 2003
I have the same issue. Did you manage to put it back on or are you still trying?
Thanks!
Old May 9, 2026 | 06:23 AM
  #42
SilverSound4's Avatar
2004 C230K 2 door coupe 1.8l m271 6 speed manual
Originally Posted by nlpamg
This is a guide to getting access to your throttle body in order to clean it.
Please use this at your own risk.
First, make sure the car is off and the key is not in the ignition.
Locate your airbox and disconnect the piping and move it to the side so that you can get access to the throttle body.
There are two tabs circled in this picture. Use a flat head screwdriver to push down on the tabs (see the arrows) and slide it forward towards the bumper of the car. Keep in mind, there is a tab on the bottom, so once you have loosened the tabs, move it forward and up to the left.
From here, you'll see the tube that connects the intercooler to the throttle body. The throttle body is connected to the tube by a hose clamp (circled) and a bracket that is mounted by two screws (circled).
The hose clamp is easily removed by using a flat headed screwdriver.
You then need to remove the two screws below:
Then, pull the hose off of the throttle body by pulling the hose forward towards the bumper of the car and to the right. This is what it should look like when you've done the aforementioned.
Now, that's one dirty throttle body!
We cleaned it off with paper towels and q-tips and a couple light sprays of throttle body/air intake cleaner:
This is what it looks like when it's clean
To put it back together, follow these steps.
Push the hose back into the TB;
Line up the bracket and put the screws back on;
Tighten the hose clamp;
Put back the airbox piping--you must first secure the bottom tab into the airbox, then put the top tabs in place.
Done!
Hope this helps.
Thanks so much to Splinter for helping me do this (he basically did 99% of it). Thanks for your hospitality and welcoming me to your beautiful home.
ugh where is the photos?
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
