P0456 - Small Evap Leak
Old Mar 16, 2009 | 06:00 PM
treiberg's Avatar
2003 C230 and 2005 C230
Check Engine lights give code P0456 (on '03 C230), which is a slight leak from evap system. I keep resetting it and it keeps coming back, even with gas cap srewed in tight. Anybody out there found a solution? I guess I may need to replace my gas cap. How do you remove the cap, or is it possible to just replace a seal or o-ring in the cap? What else should be checked? Hoping folks out there have found a common fix for this one. Thanks.
Old Mar 16, 2009 | 06:09 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
It could be numerous things. I had this code on my 05 C230 and it turned out to be a small leak in the fuel filler neck.
Old Mar 16, 2009 | 06:49 PM
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
I've had/have the code as well:
https://mbworld.org/forums/c-class-w...-cold-cel.html
good luck and let us know what happens
Old Mar 16, 2009 | 07:04 PM
Glyn M Ruck's Avatar
Super Moderator
Oh! dear - here we go again - could be charcoal canister or cap or a leaking purge valve. I recommend you start with a smoke test of the system under pressure.
Old Mar 16, 2009 | 08:58 PM
LILBENZ230's Avatar
A smoke test is what it took on my car to diagnose it. This was after they threw a purge valve at it as a guess.
Old Mar 23, 2009 | 11:21 PM
treiberg's Avatar
How do you do a smoke test? I searched to no avail....
Old Mar 24, 2009 | 10:23 AM
drb930's Avatar
2005 C230 Sport Coupe
Subscribed!
Old Jan 6, 2010 | 01:00 AM
Flame3g's Avatar
CLK500 SPORT
had this code happen on monday and took it to the dealer....P0456.....fuel filler neck fitting part was $469....not covered under cpo warrenty...
Old Mar 13, 2010 | 05:00 PM
06E55's Avatar
2006 E55, 2012 Bentley Continental Supersports Convertible, 2014 Kia Sorento SXL AWD
What charcoal canister are you referring to? I just had my CEL come on last night in an 06E55 and this was the code...
