Door Seal-Weatherstrip Replacement
Old Mar 21, 2009 | 03:07 PM
Nicholi2007's Avatar
2015 C400 Tenorite Gray
I need to replace the rubber door seals on all of the doors. The rubber has shrunk and the driver's side is particularly bad.
Does anyone have any experience with this? If so please advise on the steps, tools, and materials needed. Thanks
Old Mar 21, 2009 | 07:19 PM
WaveyKat's Avatar
Something Slow
Tools: Your Hand price FREE
1. Pull up plastic trim at the bottom of the door!
2. Remove weather strip.
Install in reverse order!
Old Mar 21, 2009 | 09:23 PM
BlackLiquorish8's Avatar
C3Twon AWD Jumpofffff
what year is your car? must be from the sun and heat in Cali
Old Mar 21, 2009 | 11:48 PM
c230yvr's Avatar
Thought it might be useful to add to this thread... my weather strips were covered in wax, and I couldn't figure out how to clean them. Someone suggested Mothers Back to Black and it easily dissolved all the wax. You can tell by the feel of the stuff (its super oily) that it protects rubber well, from drying/cracking.
Old Mar 22, 2009 | 05:21 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
That's weird. EPDM is known to be extremely weather resistant.
Yes, you start from the bottom and pull. It's held on by some clips, so just pop the trim off the clips one by one.
Old Mar 22, 2009 | 01:50 PM
I have a 2002. Its always been a west coast car. The rubber over time subjected to temperature changes, particulates in the air, etc has cause the seals to shrink.
I wasn't sure if one was suppose to use any kind of light glue before putting it on. I am going to place an order. I'll post pics later.
Thanks fellas
Old Mar 27, 2009 | 02:09 PM
I presume the inside door panel needs to be removed first then I'll have access.
