DIY Fuel Filter Replacement Question
Old Apr 1, 2009 | 03:00 AM
jim628's Avatar
Hello:
In reference to the following link:
https://mbworld.org/forums/c-class-w...placement.html
Is it necessary to relieve the fuel pressure?
What is the purpose?
I have never change MB fuel filter but I have done it on a Honda
and did not bother to relieve the pressure. Ofcourse the car used
carburator, not fuel injector.
Thanks,
Jim
Old Apr 1, 2009 | 03:43 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
\ You need to relieve for safety reasons. Its a high pressure system... You don't want gas shoot everywhere when you take out the filter.
Here's a little more detailed diy.
http://www.installuniversity.com/mb/...uelfilter.html
Old Apr 1, 2009 | 10:25 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Wear some safety goggles.
Old Apr 1, 2009 | 10:32 PM
BlackLiquorish8's Avatar
C3Twon AWD Jumpofffff
does anyone know what's the recommended mileage to change the fuel filter??? i'm sure my car is due i have 90k
Old Apr 1, 2009 | 11:06 PM
dnlow's Avatar
2005 c230k
service manual has information you need
for '05 c230 it says 65k or 5 years.
Old Apr 5, 2009 | 11:48 PM
dnlow's Avatar
2005 c230k
I just did this DIY today and it is pretty easy. I would recommend some gloves because even with the pressure released there will still be gas that leaks out. Not much but about 1 1/2 cups worth, so a fair amount. Also purchasing some new hose clamps will make it easier. The hose clamps MB uses will probably need a special tool to put them back on.
The only issue I had was that the CE light came on because the car ran rough for about 10 seconds (just had to get the air out of the gas lines). It smoothed out and I went to the auto parts store to have it removed.
Old Apr 6, 2009 | 10:19 PM
wvadam's Avatar
C230 COUPE 2003 M271
Originally Posted by jim628
Hello:
Thanks,
Jim
I never released any pressure other than taking the hose off the fuel filter and the gas came out. Its hardley any pressure so long as you let it sit for an hour before doing it. And it took about that long to get my tools and remove that cover etc.
the only 2 things i would say are 1) draing the gas into a pan, about a cup, and 2) make sure you leave the key in the run position for a good minute or 2 before you start the car to get the fuel system charged properly.
Old Apr 6, 2009 | 11:40 PM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
Done it three times and have never released the pressure. It is maybe 4 oz of gas that comes out.
Ed
