Center Arm rest issue
2005 C230K Sedan.
I Just latched back (outward) the two little hook things that are at the rear of the arm rest. HOLD the two buttons as tight as possible with out breaking the buttons (this will keep the little hook things in the rear of the arm rest latched back) and slide in the arm rest from rear to front (keep an eye on how you do it, there are little metal pins that are supposed to slide in. You might have to fiddle with it once you slide it in there, it took me a good 10 tries to get it in there because i kept letting go of the buttons. I THINK you can do one side at a time if you're not able to push both buttons tightly at the same time. Hope this helps.
Let me know if you needs pictures of what i mentioned above.
Chris
1. Hold down both rear latches with one hand, then hold *ONE* button tight and it should keep both rear latches down. If you look carefully at the four retractable pins you need to fit, the ones on the side of the button you're holding will be better positioned (i.e. retracted further / shorter) so work on that side first (I did the driver's side from the driver's seat first).
2. While continuing to hold that button firmly, place the armrest in the correct orientation (cushion up, front forward, parallel to ground) working first to fit the rear pin on the same side as the button you're holding. Takes a little trial and error, but once that's in place don't let it jiggle out or else you have to start over.
3. While still holding that same button, next fiddle with the front pin on the same side until it fits into the slot. I could be wrong but if you release the button accidentally I think it should be okay as long as you keep the rear pin in place - just re-push the button and keep trying. Once you get both pins on one side in, you're essentially there because it's close to (but not exactly) the natural opening state where the armrest hinges on the front and rear pins you just fitted on the same side.
4. The rear latch on the opposite side has now snapped back into the closed position so manually flatten it again (with the armrest still open) and firmly push and hold the button on the open side. This holds the latch flat and retract the pins. Close the armrest to proper position while still holding the button, release the button when it seems to be in the exact normal position, then jiggle lightly until these remaining two pins slide into place. Repeat as necessary till done.
PITA if you have to do it, but after doing once I'd guess I could probably do it again in 3-5 minutes, depending on a little luck. I've learned so much reading this forum already, hopefully this might save someone else a little time and headache. Good luck!
Peter
Finally just drove over the the dealer (3 blocks away) and they popped it back in without even turning the car off. I was on my way in 60 seconds. Not sure what they did, but it hasn't popped back out in 2 years.
Peter
Peter
