DIY: M271 coolant drain/fill
Old Oct 24, 2010 | 10:58 PM
  #51
samaritrey's Avatar
Super Moderator
THE C350
Originally Posted by maverik259
where do you get distilled water from?
grocery store
Old Oct 24, 2010 | 11:03 PM
  #52
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
haha well i'll just buy the pre-mixed stuff so i dont have to worry about it. But ya i didnt realize you could.
Old Oct 25, 2010 | 10:19 AM
  #53
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
Walgreens, CVS, and all grocery stores have distilled water. Less than a dollar for 1 gallon. Even some gas stations sell distilled water. You just have to look in the right place in the store.
Old Oct 25, 2010 | 11:57 AM
  #54
maverik259's Avatar
ya...well im doing a Tstat install this week and i ordered the zerex g05 coolant since it was half the price MB wanted for a gallon. and its 50/50 so i'm not gonna worry about mixing in distilled water...
Old Oct 25, 2010 | 07:29 PM
  #55
Utahkompressor's Avatar
W124, W203, W204, W251
Just to give you an additional information!
M271 also have an engine block drain plug right under the exhaust manifold (red circle in the picture)...drain that too to get everything out!
Attached Thumbnails DIY: M271 coolant drain/fill-img_3700.jpg
Old Oct 25, 2010 | 09:22 PM
  #56
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
My car has been giving me erratic "Coolant Check Level" messages since August. They're pretty constant, now, though and it is not the washer fluid. As was mentioned earlier in this post - I am pretty sure that was a pre-05 thing and that the 05+ are fixed. Perhaps it was somewhere after production began on the 05s, though, as Phil has a pretty early build 05.
I can't find Zerex G-05 anywhere.
Old Oct 26, 2010 | 01:42 AM
  #57
maverik259's Avatar
lol that is a horrible location. How in the world did you drain that plug? just duct tape a tupe to it or something and let it drain down under the car to a pan?
Old Oct 26, 2010 | 04:38 AM
  #58
Glyn M Ruck's Avatar
Super Moderator
Matt - See if you can find (Chevron/Texaco) Havoline Extended Life Antifreeze Coolant - approved against 325.3
It's a better product than Zerex G-05
Old Oct 26, 2010 | 10:54 AM
  #59
maverik259's Avatar
haha o man that woulda been better to know before i ordered the zerex...
Old Oct 26, 2010 | 11:35 AM
  #60
Super Moderator
Don't worry Mav. Half the forum run on Zerex
Old Oct 26, 2010 | 01:44 PM
  #61
There is actually a special tool that goes in there with a tube, but I don't have one. So, I just put a pan under it and catch whatever I can.
Old Oct 26, 2010 | 04:08 PM
  #62
maverik259's Avatar
haha ok...
Old Oct 26, 2010 | 04:26 PM
  #63
LILBENZ230's Avatar
Can I top off my factory fill with 325.3 coolant?
Old Oct 26, 2010 | 06:16 PM
  #64
Super Moderator
Not a good idea. Change it.
Old Oct 27, 2010 | 04:45 PM
  #65
maverik259's Avatar
anyone have a good suggestion for removing this Tstat...i pulled the bolts out and removed the hose from the black elbow that i guess houses the tstat, but that darn thing will not come out of the engine...it will turn 90deg to either side but it will not come out of the engine block...
Old Oct 27, 2010 | 04:59 PM
  #66
I used a thin flat head screwdriver to pry it out. I actually did it with the hose attached, so there is more area to pull on.
Old Oct 27, 2010 | 05:02 PM
  #67
Twist it about 10 degree before you pry it, so you don't damage the machined surface.
Old Oct 27, 2010 | 07:33 PM
  #68
maverik259's Avatar
got it out...but now 2 things...
1) the one i pulled out looked just fine.
2) a gallon wasn't enough coolant and thats all i ordered. Can i buy another gallon (different brand) from the local auto shop and add that on top? I'm 20 miles from the closest dealership and I'm afraid to go really far w/o enough coolant. I mean i can see it in the canister but its at the bottom and the light is on telling me it is low.
Old Oct 28, 2010 | 12:13 AM
  #69
What is the reason you pulled the tstat? Did you get CEL?
Mine looked just fine too when i pulled it out, but I changed it because I got P0129. I boil my old tstat after i took it out and it started to open at 80dec.C when it's designed to open at 90dec.C......and that's how you test it, outside appearence doesn't tell you anything!
You can just top the coolant with distilled water...a little less than 50 percent mix is fine because you live in FL.
Old Oct 28, 2010 | 01:02 AM
  #70
maverik259's Avatar
i thought you wanted more antifreeze for hotter temps?
Old Oct 28, 2010 | 10:28 AM
  #71
pcy's Avatar
pcy
if you are still haven't bought the second gallon of coolant, you can actually fill the engine with distilled water and drive without any problem. Since you are only going for 20 miles and coming back. It shouldn't be a problem.
After you come back with the second gallon of coolant, you can drain the water and fill with coolant.
Old Oct 28, 2010 | 04:03 PM
  #72
You actually need less antifreeze in hotter climate. If you buy an antifreeze that require mixing it will say on the bottle...the higher percentage of antifreeze, the better protection against negative temp. In Thailand, we only use 35% to 40% antifreeze...it's just there to protect the radiator and engine against rust build up, it doesn't make your engine run cooler. Hence, the term "antifreeze".
Old Oct 28, 2010 | 09:15 PM
  #73
maverik259's Avatar
good point...well im just happy that it finally got the cel to go off today...not sure how a bad tstat can throw 2 errors but it was.
Old Mar 16, 2011 | 04:40 AM
  #74
W203E35's Avatar
2006 C350 Sport 6MT
Thanks everyone, I too recently started to get the coolant message. Not the wiper fluid so I guess it's the coolant. I'm thinking of doing a full flush. At 60k is this overkill? Should I top it off or just go ahead and do it. I read somewhere that fluid flush is 15years or 150k miles??
I noticed Glyn mention 325.3 but this one that I see is a 325.1? http://www.rmeuropean.com/Part-Numbe..._5C1313F8.aspx
I guess I can go with Glyn's recommendation (Chevron/Texaco) Havoline Extended Life Antifreeze Coolant.
File Type: pdf
File Type: pdf
Old Jul 4, 2011 | 03:54 PM
  #75
Mercury's Avatar
2005 1.8 B/B
Originally Posted by seagel1000
So i'm going to be performing this today or tomorrow.
I'm not sure where to find this "cap" on this step:
-What I did is flush the old stuff out with tap water...just open the cap and put the garden hose in there and wait for a few minutes.
-Wait for the tap water to drain out, then tight the plug back on.
Any one have a pic or can guide me where to find this cap?
I'm about to flush the system out since i have to replace my auxiliary pump tonight or tomorrow. Any suggestions or add-ons tips that any one wants to give me on top of what was posted on the step by step by the OP.
Thanks!
I have a similar question as he did.
Do we have a radiator cap like other cars ( please see picture below)
Or do we just drain out the coolant and fill it up from the reservoir?
Thank you!
Attached Thumbnails DIY: M271 coolant drain/fill-impp_0802_06_z-infiniti_g35_sedan-nismo_radiator_cap.jpg
You have already rated this thread Rating: Thread Rating: 2 votes, 3.50 average.
