Resetting The Loop Help!
Can someone give me instructions on how to do this because I don't think the dealer knows. They've attempted to fix the changer 3x to no avail.
I know you have to hook up the system to a laptop. What program do they use and what is the procedures?
Really "CD changer not present" or "magazine" not present?
If the magazine removal causes the CD to go not present, must be hardware related to the the Changer or the magazine, the SW for the loop is static. However the motion of the removal might jostle the connections in the rear of the Changer. I would start with making sure all connections are good and tight.
1) check connections
2) have dealer actually replace the Changer and magazine with a new one. They will, if you squawk about it.
BTW I am pretty sure the CD present is in the same DAS menu as NO Phone. for your original idea:
In stardiagnosis :-
Control Units -> Info. and comms. -> ICM -> Control Unit Adaptations -> Version Coding -> Optional Equipment
In the optional equipment menu you can set the following
to present or not-present depending on what you have
AUDIO, Tele-aid, Cellular Telephone, Trip Computer, Navigation
Should be AUDIO I assume.
Good Luck
