DIY Right Front Axle
Old Apr 18, 2009 | 03:13 AM
bz6039's Avatar
2003 C240 4-Matic
anyone know if there is a DIY for this? i couldn't find anything by searching..... any help is greatly appreciated... the stealer wanted $1275 installed....935 for the part and the rest labor.... also i searched for the part and didn't find much??? Help!
Old Apr 18, 2009 | 01:42 PM
Glyn M Ruck's Avatar
Super Moderator
Don't have a DIY - will let you know if I find one
You are talking about replacement of item 10 - drive shaft with CV joints?
Presume the CV joints are shot? If so have you got a quote to rebuild the CV joints from an Indy?
Old Apr 18, 2009 | 08:33 PM
bz6039's Avatar
2003 C240 4-Matic
I was told that i needed to replace the whole axle? both CV boots (upper and lower boots on the axle) were ripped on the right... the grease came out and i assume it ruined the item 10 you are talking about.... i didn't know they could be rebuilt? how do i obtain a quote from Indy? thanks for all of your help.
Old Apr 18, 2009 | 10:27 PM
Super Moderator
You need to find a shop that specializes in CV joint rebuilds. Hopefully a member can help. In South Africa we can heve them rebuilt so I'm sure it can be done in the US. Here it saves a lot of money. Your labor rates are higher so ??? I don't know there.
