vacuum line help 01 C320
Old Apr 22, 2009 | 05:05 PM
timmified100's Avatar
2001 C320
Greetings, I have a missing vacuum line on the back of the intake manifold on my 01 C320. It has a piece of black rubber about an inch long going nowhere. The diagram I have only shows the plastic line going to the purge valve and the line going to the top of the throttle body which are both connected. Also the plastic one going to the brake booter is connected. Does antbody no where this vacuum line connects coming off the steel niple on the back of the intake? Thanks for any advice/pict/diagram Tim
Old Apr 22, 2009 | 08:39 PM
krisv420's Avatar
02 C320 Sedan
Hey Tim,
If you could take a picture of what your looking at ill take a picture of how it looks on my car. Hope this helps a little
Old Apr 22, 2009 | 10:11 PM
2001 C320
thanks so much. I won't have ant time till this weekend. I will repost asap thanks again Tim
Old Apr 23, 2009 | 06:25 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
if you are talking about the line on the driver side manifold towards the rear the line on the 32's connected to the airbox. forgot if the normal M112's connected to anything. I remember MJ50 just leave it out on his 240 and it's fine.
Old Apr 23, 2009 | 02:45 PM
2001 C320
Wow, I hope it doesn't go to the air box as that woul'd be hard to connect while putting on that big cover. I'm throwing a secondary air injection malfunction code also(P0410), but I don't believe it's related because all the vacuum lines for this appear to be on the front of the intake manifold. Can anyone confirm. Thanks
Old May 21, 2009 | 04:14 PM
jscavo's Avatar
w203
I had the p0410 also. replaced the check valve people have mentioned (back of engine on 2002 m111). pain to replace but its been a week with no CEL and the 30-60 second cold startup idle is much smoother.
Old Dec 14, 2018 | 08:12 AM
huotalicusC200K's Avatar
w2010 w204 c300 amg sports package
vacuum line where does it plug into???help
you can see where it comes from the light grey almost white colour next to where the blue line is
this photo shows where it comes from under the manifold area and routes along the firewall along with the fat cabling
this is the plastic tube from the rubber vacuum running along the firewall with the fat electrical cable
hi can anyone help me i have a loose vacuum line on my 200 w204 c200k here in australia
andi just need help locating where to reconnect it i have tried looking for a rubber hose but cant seem to find it
it comes off a metal valve
