Fault Codes
Is this all the fault codes for a Merc?
http://www.bba-reman.com/content.asp...on_fault_codes
I'm trying to make a program (free), where a user can search the fault codes and get a description. So I was wondering if this is all.
For Example:
Search a fault code and see that the problem is
Door Controller
Symptoms window will not work from the switch and door locks not activating.
-----Edit-----
Also if you guys have any other ideas throw them at me. As most of you know I recently became a "statistic"
