Strut help!
Old May 11, 2009 | 11:14 AM
drastic's Avatar
2002 c320 wagon
Strut help!
hello! by any chance, anyone has pics of the difference between the regular struts and a sport edition strut. i want to be sure if there is a difference before i replace mine. i would like to use the sport ones if the are shorter than the regular ones on my 320 wagon. thanks in advance for the help!!!!
Old May 11, 2009 | 06:02 PM
Glyn M Ruck's Avatar
Super Moderator
Fit Koni yellows!
Old May 12, 2009 | 07:24 AM
drastic's Avatar
2002 c320 wagon
wheres a good place to get em?
Old May 12, 2009 | 09:17 AM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
You could try google or some other internet search engine for Koni and do some research on web.
Old May 12, 2009 | 09:28 AM
johnp's Avatar
08 Silver Lexus IS250 (manual),73 air cooled super beetle-- black 2004 230 ss is gone
I got mine off E-Bay. About 4-5 yrs ago, they were only about $500
Old May 12, 2009 | 11:20 AM
drastic's Avatar
2002 c320 wagon
kool cuz i need something shorter than stock. so that it will lay when aired out. with the stock ones it wont drop much.
Old May 12, 2009 | 02:18 PM
howardyudoing's Avatar
07 c230 sport
i hear kyb gives the best ride quality.
Old May 12, 2009 | 02:25 PM
skittles's Avatar
Moped
are you serious? KYB? whats the height though?
Old May 12, 2009 | 05:33 PM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
I had KYB and changed to Koni on my old Datsun (Nissan). Don't waste your money on KYB. You'll be changing them out after about 30k miles - just like the original Datsun shocks.
By the way, shocks don't have much influence on your ride height - it's the springs that do this. But - if you cut the springs (or installed short springs with std. shocks), then the shock isn't working in the middle part of the range of motion - thus any variable damping will be fouled up.
Old May 12, 2009 | 05:59 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Get a 'cup kit'.
Shorter springs and appropriate shocks...or perhaps contact the
mfg and see if they just sell the struts...
Eibach or HR I think
Old May 13, 2009 | 02:41 PM
drastic's Avatar
2002 c320 wagon
thats why i am looking for a shorter one dmatre. when using shorter springs, i know theres less travel and maybe some bottom out in hard dips or bumps. i can be wrong but i dont think the difference between a regular C and either the sport or amg is merely based on the coil spring as far as handling and height is concerned.
