Renntech Muffler Install
I took the Renntech muffler off and picked up the extra power and it was across the power band, actually looked good on the dyno. The loss of backpressure didn't seem to bother the car and rewarded me with the extra ponies. It's hard to compare the sound of the straight pipes to anything but I'll try. This was indoors in a garage, at idle and low RPM it was wonderful, not loud at all, a deep hot rod rumble. I would compare it to a Harley with aftermarket pipes, not a Harley with straight pipes. Even then it sounded quieter than a Harley and deeper. At higher RPMS the engine noise competed with the exhaust so it didn't make the room any louder than it already was, just different. Keep in mind I have the resonator and this was indoors and there was a wall about 4' from the back of the car to echo the sound. It would sound quieter outside and I don't think you would get stopped or ticketed, it just not that loud. I'm think about putting in a Y pipe with a valve to bypass the muffler at the flip of a switch.
the cat probably produced enough back pressure and I wonder if u picked up any power by removing the resonator
so did you test how much power you picked up from the intercooler since your last run?
Yes, with Renntech and without any muffler, no muffler won by 5 1/2 HP and 6 ft-lbs torque and it sounded better. Here's the pic of a the disconnected Renntech muffler on the dyno.
so do u know approx. how much hp u could have gained with the renntech or no? How much HP do u have now total with the intercooler and exhaust.
Did you do any before/after intercooler dyno?
Could intercooler lose power because lost of pressure while the cooler weather could compensate
the heat soak problem of the intercooler?
I didn't do a before/after dyno on the muffler, too anxious to get it on. I don't know what went wrong but I actually lost HP from stock and I'm still investigating to see what went wrong. At first I thought it was a blockage in the muffler but without the muffler I had only a 6HP gain and wouldn't account for a HP drop from stock with a pulley and intercooler.
maybe its the new ASP pulley with the steel sleeve making the difference. Are the fuel setting the same as when u dynoed last?
