Both Remote Keys Not Working - FIXED!!!
Old May 26, 2009 | 06:02 PM
loudbmw's Avatar
17 E300, 17 C300, 14 C250
2005 C320 with 60K miles. Got home from a weeks vacation and neither key would unlock doors in rf (radio frequency) mode. Keys did work in infrared mode if held close to driver's side door.
Put new batteries in one remote - no difference. Went to check fuses (fuse chart missing of course). Found one on line:
https://mbworld.org/forums/c-class-w...e-box-map.html
Pulled fuses 8,9,21,22,32 & 33. All were good.
Tried remote key again after pulling fuse - you guessed it, both keys now work perfectly!
That's what I call a cheap fix.
Lou
Old May 26, 2009 | 06:26 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Odd. Could it be that reseating the fuses cleaned up the connections a bit?
Did you see any corrosion?
Old May 27, 2009 | 02:41 AM
Glyn M Ruck's Avatar
Super Moderator
Could have rebooted a micro processor somewhere by pulling fuses & cutting power.
Old May 27, 2009 | 01:19 PM
jscavo's Avatar
w203
had similiar fuse issue for pano roof. went to use it for the first time since before the winter and nothing. check the fuse map and pulled the pano fuse, it looked good, put it back in and it worked. lucky.
Old Mar 21, 2022 | 10:11 AM
bekkerh's Avatar
W202
Hello all,
1st post , been doing a bunch of reading and research here. Bought a W203 a week ago and trying to resolve the central locking issue. Sedan car
IR works, new batteries in fobs. One new fob, one original - original IR does not work
#8 fuse OK, replaced anyway
FM radio signal fine, AM is so-so (but I guess thats normal?)
Car had a flat battery before I bought it, ex-owner replaced it (something here?)
Car has a tint - ex-owner says the RF still worked after tinting
I would greatly appreciate any help!
Old Mar 21, 2022 | 11:45 PM
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
Originally Posted by bekkerh
Hello all, 1st post , been doing a bunch of reading and research here. Bought a W203 a week ago and trying to resolve the central locking issue. Sedan carIR works, new batteries in fobs. One new fob, one original - original IR does not work #8 fuse OK, replaced anywayFM radio signal fine, AM is so-so (but I guess thats normal?)Car had a flat battery before I bought it, ex-owner replaced it (something here?)Car has a tint - ex-owner says the RF still worked after tinting I would greatly appreciate any help!
Had exactly the same issue you are describing. See below thread.​​​​​​​​​​​​​​ ​​​​​​​https://mbworld.org/forums/c-class-w...ob-issues.html ​​​​​​​You will need a new antenna amplifier.
