Just bought a COMAND unit
Can anyone answer any of my last 2 posts because I really would want to buy that adapter now so I can get it as soon as possible. Maybe there is someone here that can read german and translate the auction for me?
I just realized I can translate the page in Ebay.
http://74.125.95.132/translate_c?hl=...kJZtCrPWBpY_HQ
So I am assuming that this adapter plugs into my original Audio 10 harness and then into the COMAND 2.0 system to make it work without cutting wires, right? My car's build date is 12/2003.
You don't need a CANBUS simulator, your car already has a CANBUS. You can buy the harness and do all of this without cutting any wires. You will need to run the CAN wires to the passenger side floor board area and hook them in there to the termination block. The original plug that is in the car now will plug into the harness. Try amgkit.com as they had the C1 / C2 adapter the last I knew and you need to get it with the CAN wires installed.
So, you need COMAND (You have), 203 820 09 75 – Navigation antenna, C1 / C2 adapter with CAN wires, T20 driver, flat blade screw driver, and about an hour. With all the right stuff this is an easy project.
Also, the correct location for the antenna is under the dash above the instrument cluster.
Good luck.
Good luck.
Good luck.
Good luck.
Ok I just got the Comand in the mail today. And now that I have it and I'm looking at it I want to know what goes where if someone could help. I numbered them so if someone helps me out they can refer to what number they are telling me about. Also #4 has a green tab in it, I can take it out and put it back in. I'm not sure if its used for something or not.
#32
If I buy that C1 C2 connector from amgkit.com and it does not come with CAN wires, is that a problem? Do you have an MSN or AIM so I can ask you a few questions about this, if you have time?
#35
2013 C300 4Matic Sport
Great thread, tell us how it worked out! I'm thinking of doing this myself on my 2002 - this looks like what I'll have to do, as mine won't be plug and play either
#38
MBworld Guru
white and whiter
I found the DIY instruction I used when I did the Comand 2.0 myself. saves you some trouble to write a diy.
here's the link http://www.mercupgrades.com/COMAND+R...article-1.html
#40
#41
Will this really fit W203?
http://cgi.ebay.com/Mercedes-Benz-DV...3286.m63.l1177
This obviously isn't Comand 2.0...however this ad says W203 <'04
EDIT: It's the newer comand APS, DVD Based system - Nevermind!
#43
It seems everyone prefers the Euro vs US command. Is the only reason the DVD play back. I assume on US version you can play a CD while the Navi is running and on the Euro you can't use both because of only one dvd drive? I had a chance to buy a US spec but it has no DVD playback capability.
#44
www.benzworld.org/forums But i suggest you have it fitted at your local MB dealer. If the plug and play lead is available on your car you still have to have the can lines entered by computor also phone etc.
#45
Well, I finished the install and everything went pretty smooth. Only problem was that I did not have the right Torx wrench so I sent my brother out to Murrays to get me the correct size. I was surprised at how easy it is to actually remove the center counsel. Everything basically snaps back into place when you apply pressure to it.
I believe people have my Comand confused with the newer comand that has a DVD drive. I have the older model comand 2.0 that is a CD based comand.
Actually I have a question too if anyone can help me. Does the HU itself only play the navigation CD's? Because I put in an audio CD and it did not play it back.
