"Chirp"
Old Jan 23, 2002 | 04:19 PM
VoyagerDude's Avatar
2002 C230K, Silver, 6-speed, Evo, Roof, Leather, CD, Staggered C7 Wheels
"Chirp"
I remember some discussions on this earlier...
Is it possible to set the C-coupe chirp when you lock/unlock the car? (with or without factory alarm)
Thanks in advance
Old Jan 23, 2002 | 04:29 PM
young's Avatar
GLB 250 4matic
flashman, i think this question can be added to the faq. i'll put together the info if you'd like. what do you think?
in addition to this, we have good info on the fuel settings too. and the cd-changer install info (thanks to pete)
Old Jan 23, 2002 | 05:43 PM
young's Avatar
GLB 250 4matic
chirp info
thanks to Mark Cummins (i slightly edited the text for clarity and typos):
First you must have the MB factory handheld lap top tester go into the system
go into programs
then locate the rear SAM program
then locate body
then norway
and wa la
it's there to program the chirp,chirp,chirp on locking and a single chirp on the unlock
Old Jan 23, 2002 | 05:47 PM
young's Avatar
GLB 250 4matic
cd changer installation info
Pete's website
Old Jan 23, 2002 | 06:24 PM
Thanks for all the info.
Is the chirp available with no factory alarm as well? If yes, what makes the chirping sound, if there is no alarm siren in the car?
Old Jan 23, 2002 | 08:32 PM
Rick's Avatar
C230K Coupe/Orion/C4/C5/CD/AMG Spoiler/V60/TeleAid, 2 MGB's
There's a siren....just press the panic button on your smartkey to check.
...or...you can do a real world test by throwing a brick through YOUR drivers side window and unlocking the car from the inside....
Old Jan 23, 2002 | 08:43 PM
Flashman's Avatar
2002 Mercedes-Benz C230 Kompressor Sports Coupe
Yep, I need to add a couple different things to it. So I will do it all as a batch and add it.
Old Jan 23, 2002 | 09:03 PM
Lynn's Avatar
In Canada the alarm is an option, which VoyagerDude apparently doesn't have. He may not have the siren.
Old Jan 23, 2002 | 09:29 PM
Fuzzo's Avatar
is this the same procedure for the sedans as well?
Old Jan 23, 2002 | 09:30 PM
Lynn's Avatar
It should be the same for sedans. I think some of the members who own sedans have had it done.
Old Jan 23, 2002 | 09:34 PM
young's Avatar
GLB 250 4matic
i should post a disclaimer. i have not done this procedure as i prefer the visual cues. mark cummins said he had it done on his wife's coupé. Kwik has it on his E320
the info that i read was that this procedure is possible for ALL late model MBs - so yes, i would think it should work for the sedans also.
please refer to this thread to see actual discussion:
audible chirp
Old Jan 23, 2002 | 09:46 PM
Lynn's Avatar
Young, I thought I read in one of the various posts on this subject that this only worked on C-class cars.
Old Jan 23, 2002 | 10:06 PM
young's Avatar
GLB 250 4matic
i didn't see that (but i've been wrong before ) but Kwik said he had it done on his E class car and adam said it was possible on 2000+ model E classes also.
here are 2 links for that:
https://mbworld.org/forums/showthrea...ghlight=norway
mbtech has a small warning in this thread - about possible errors and chirping not for US - is this an implication that CLs can have it too?:
also, small note about MLs not being able to do this as they use a horn instead of a siren???
Old Jan 24, 2002 | 12:27 AM
That's right Lynn.
There is no panic button on my remotes (and probably no siren).
So no chirp for me I guess.
Old Jan 24, 2002 | 07:31 AM
Richard's Avatar
2004 SL55, 2015 A250d, 2016 GLC250d
Theres no panic buttons on UK remotes, but we do have additional sirens. I think we have the additional siren in the ML aswell [when my wife comes back i'll test it, if no siren i'll post]
Old Jan 24, 2002 | 08:04 AM
CarlssonCl203's Avatar
01` Sportscoupé 220CDI
i have the same problem has you Richard Portugal remotes doesnt have the panic button too
Is there any option for us
Best regards
Bruno F.
Old Jan 25, 2002 | 09:28 AM
young's Avatar
GLB 250 4matic
while i was skimming this months issue of merc enthusiast, there is an article about diagnosis software. at the end, they mention some software that can change the settings (like DAS) of late model german cars - i think it said it costs £1500. comes w/ connectors and i think all you need is the computer.
i didn't read it fully, but i will monday and post more info if people are interested.
Old Jan 25, 2002 | 09:32 AM
revstriker's Avatar
K Car
Young, Thank you for the info. Please do post more when you have read the article.
Thanx....
Old Jan 25, 2002 | 04:06 PM
Richard's Avatar
Hi
Randy B (I think it was RandyB) posted an article in the star diagnosis thread that snapon sells a unit like this - see www.snapon.com
R
