Missing parts in the C-Coupe!!!!
Old Feb 14, 2003 | 11:57 AM
Spyke's Avatar
2002 C230k
Originally posted by mctwin2kman
...A 1.8 L is an around 1800 cc engine. The 2.3 will be around 2300 cc's and the 2.6 L V-6 ion a C240 would be 2600 cc's. This is there displacement, which last i knew wa sif you strip the block of all components and then drop it in water it displaces so many cc's and that is the number. You also have to account for Bore and Stroke and Compression ratio to figure out the rest, but that is the gist of it...
Not even close... either you misunderstood what someone was saying, or they were yanking your antlers.
The displacement is the swept volume of the cylinders, as in the volume the pistons displace as they travel through their stroke. Quite simple to figure out, it's (pi )* (bore^2)/4 * (stroke )* (number of cylinders).
Compression ratio has nothing to do with calculating displacement.
Old Feb 15, 2003 | 02:34 AM
TNblkc230wz's Avatar
C320 Coupe
You can check out the MB site in England. It lists all three versions of the 1.8 ltr engine and the corresponding specs. MB is phasing out the 2.3 with the 1.8.
