Why remove coils to change plugs?
Old Jun 21, 2009 | 09:18 PM
C240driver's Avatar
C240
In a 2002 C240, the directions in the WIS Manual for changing spark plugs say to remove the coils. It appears that there is enough room to remove the boots from the plugs and remove the plugs without removing the coils. So why remove the coils?
Old Jun 21, 2009 | 09:25 PM
LinDenKid's Avatar
C230 coupe 2002
im no expert, if im not mistaken, the coil holds the plug down , its on top of it.
Old Jun 21, 2009 | 09:30 PM
C240driver's Avatar
C240
In the 2002 C240, the colils are not on top of the plugs, they are mounted on tside of the heads and have wires that go down to the plugs.
Old Jun 21, 2009 | 10:14 PM
Moviela's Avatar
It allows you to inspect the coil pack. Wipe the dirt off and look for carbon tracks from arcing. Any cracks in the case, EHT leads, or low voltage side connectors are grounds for replacement. With the packs out of the way, it is a little easier to work near the rear of engine, but you probably could do the job with them in place. There is something to be said for not disturbing an electrical connection that is working, especially one that has been "simmered" for 100,000 miles above a hot engine.
Old Jun 21, 2009 | 10:39 PM
DarthBudice's Avatar
08 E350 4MATIC
When using the 17mm crowfoot wrench as a lever to remove the plug wire
boot from the plug... wouldn't one rather use the metal cylinder head as
a fulcrum point instead of the plastic case of the coil?
That would be a $125 hard-learned lesson.
Old Jun 21, 2009 | 10:47 PM
LinDenKid's Avatar
C230 coupe 2002
as noted above , im no expert. lol
