turn signal light failure
2002 C230 Coupe
2 days ago my display showed, "turn signal F, L malfunction" the turn signal appeared to have burnt out so i replaced the bulb but there was no change, even when i put the other sides socket in it still doesnt work Mercedes says its a common issue and that it needs a new socket and a wiring harness to ground it. is this true???
Yes....but the "wiring harness" is nothing more than a wire spliced into an existing ground wire and taken directly to the socket. It's a TSB for early Cs.
2002 C230 Coupe
he said parts are about 100 bucks for either side plus 200 for labour which is hour and a half, any ideas or any DIY steps i can maybe use to avoid paying them?
2002 C230 Coupe
Well I dunno if it's related or not but the driver side marker, the side light. Failed to. Is this a trend?? Or a sign that it ****s up. Or just unlucky.
Technical Support/Service Bulletin.....they are listed in a sticky at the beginning of the forum. https://mbworld.org/forums/c-class-w...bulletins.html
Search on the TSB number and related turn signal posts. Most had it done under warranty so the particulars of the TSB are unknown. I seem to remember the purpose of the added wire is to give solid ground to the bulb socket. If you take it out and look it may be obvious. And yes, the side marker is related to the problem as well.
2010 C300, 2012 Mustang
If your under warranty, there shouldnt be a cost for the sockets/wiring
I suggest going to a local benz master mechanic to see what their input is. If something needs to be changed, the cost of labor is usually half of what the benz dealer charges and the parts are at about a 10% discount
1 Post
03 W203, 13 E350, 13 W204, 14 C218
a little off topic. my turn signal went out and I wanted to get the new turn signal lights for the mirror but i have an 03 so i have frosty ones can i just by the ones for 05+ and it will fit fine or do i need the whole mirror?
