FS: Blisten PSS9 Coilover + swap for stock + some cash
MBworld Guru
white and whiter
unless someone wants the coilover so they can lower their cars a lot. which the pss9 doesn't. LOL
i'm interested if kira just sell it straight and then i'll sell my tein ss.
I drive a Toyota Hybrid...
Here's what I've understood so far for this thread:
There is an order to this:
1) XsuperbeeX <-- Won't be back till Aug. OP might not have car towards late July
2) ??? <-- no idea
3) Me <-- confirmed by OP
4+) ... Better get in line
And the deal works somewhat like this:
Meet Up Kira in SJ or a place where both agree.
So far, Sonics is where Kira has recommended to me.
So it's
Your (Buyer's) $500 + Stocks + Labor for the switch
For
Kira's (Seller's) Bilstein PSS9's.
**Is hoping first and second in line default out![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
2) ??? <-- no idea
So it's
For
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
1. your car is a C280, is it 4matic?? if it is you are out of luck
2. i was looking up on tirerack 2006 MB C280 i don't see any suspension mod poping up so let's hope some MB guru can help clear things out...
i don't think is big difference since we all use similar chassis but still wanna be 100% sure before we start the work bilstein PSS9 part number (F4-GM5-8860-H0) same for 2002 coupe and 2002 sedan
3. SonicMS is first i have in mind but if you do know any shop that can do it cheaper get a quote first and see if its within your budget.
1 Post
2009 SLK 55 AMG
I don't really want to lower my car a ton, but I like the idea of C/O's.
I currently don't like how my car kind of... shifts to a side going through even freeway turns =/
Either way. If it goes down to me (because the other two people flaked), I'll most likely go through with this.
I plan on going up to 19's later, so the gap shouldn't be too big![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
Two fingers is fine with me. As long as it's not a whole Fist, like it is now![action](https://mbworld.org/forums/images/smilies/action1.gif)
EDIT::
1) It's a C280, not a 4matic. Regular RWD.
2) I really don't know this either. Help very much so appreciated guys!
I believe the C240 is just the older version of my car? Pre-06 / facelift?
EDIT::
btw, i reread my PM message box the second buyer was actually out of state
, you could say you are lucky, but i got couple things i want you to make sure
2. i was looking up on tirerack 2006 MB C280 i don't see any suspension mod poping up so let's hope some MB guru can help clear things out...![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
MBworld Guru
white and whiter
either way...if you go through with it and then decide to get rid of it. let me know.
it's about 1 finger front and back for the lowest setting on pss9. the pss9 like the kw's has big perches for the springs up front as well, so make sure you get +30 offsets if you are going 19". the suspension will fit fine on the C280.
But i think the rear is kinda tuck in...
1 Post
2009 SLK 55 AMG
Thank you Frank. +1
Members like you make me love this forum so much more than others.
And if it's my turn to go through with it, and if I ever want to get rid of it I will let you know =]
Just waiting for Kira to confirm.
PM me if it's my turn
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
EDIT:
So with my current stock wheels it should work too, right?
Here's an image: http://z.about.com/d/philadelphia/1/...o_show_037.jpg
#32
lol i need Superbee to agree first if he think is okay so i don't just ditch him all of sudden ![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
if he agree, then you be next
#33
1 Post
2009 SLK 55 AMG
Hahaha. Understood.
Maybe he'll mysteriously come back into the country and buy them![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
That would be -->
(superbee on the left, and me on the right, hahaha)
![off topic](https://mbworld.org/forums/images/smilies/ot.gif)
Btw: Question:
They'll work with my stock wheels right?
I linked to a picture before. Stock set-up, I don't really know much about offsets, and 19x8.5 or 19x9.0, etc, or whatevers.
I understand that 19 means 19", but what does the 8.5, 9.0 refer to?
And tires. Why are there 3 different numbers? xxx / xx / xx ?
That would be -->
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
Btw: Question:
#34
MBworld Guru
white and whiter
Hahaha. Understood.
That would be -->
Btw: Question:
That would be -->
Btw: Question:
8.5 and 9.0 refers to width.
tires: width in mm/ aspect ratio to the width/ rim size.
#35
Hahaha. Understood.
That would be -->
Btw: Question:
That would be -->
Btw: Question:
ok lemme use my 19inch wheels set up as example
front 235/35/19 19X8.5
235= width of the tire
35 = profile (height of the tire)
19 = diamemter of your rims
since my 19inch setup is "Staggered" means front and rear wheels has different sizes like the Plymouth Prowler is an obvious example ( http://www.seriouswheels.com/pics-19...-shoreline.jpg )
REAR 265/35/19
you get the pics
19x8.5 and 19X9.5 is the size of your rims, they are different compare to tires
there is one more
Offset... really important and i don't even really sure how u measure that...
NM pretend u didn't read my post
#36
1 Post
2009 SLK 55 AMG
Thanks for the clarifications!
19x8.5:
19" Rim
8.5" width
Then 245/35/19:
245 width in mm's for tire
35 would be how tall (height) in mm's of the tire: profile
19 is the rim diameter in inches
Thanks for the clarification guys.![word](https://mbworld.org/forums/images/smilies/werd.gif)
Offsets mean?
How would I find out for sure to make these c/o's Not rub?![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
What and how would I provide the necessary information?
19x8.5:
19" Rim
8.5" width
Then 245/35/19:
Offsets mean?
#38
1 Post
2009 SLK 55 AMG
>> SuperBee
I think Kira's family will not have the car past July, or late July.
And you won't be back until August 1st...
So really, he has to run it by you, like... can you set something up with him to do the trade before August 1st?
Otherwise...
![devil](https://mbworld.org/forums/images/smilies/devil.gif)
THEY'RE MINE! ![devil](https://mbworld.org/forums/images/smilies/devil.gif)
Lol?
Otherwise...
Lol?
#39
well not really sure when i am gonna sell the car, it doesn't matter when, i could even sell the car with the coilover on. i might able to find my old stockie but just have no clue where it is...
put the old stock on and sell the PSS9 by itself for a bit more LOL
#41
C320 coupe
Let me talk again with my parents first... even so wanting to go back earlier... its freaking boring here!!! even so the best I can do is 25 july... izzzit fine?
#44
Moped
hahahahaha!!! jordan you know ill take them if you find your stock ones but only if nobody wants them. hehehe.. i think allot of people want this but dont really have the time to do the labor part. and also people might want to keep thier stock set-up also. how much will sonic charge you to put back the stock ones?
#46
1 Post
2009 SLK 55 AMG
Here's what I've calculated to help others out.
I called sonicms:
250$ per car to do the swap
Total: $500
80$ per car alignment
Total: $160
So that's 660$ alone just to swap stuff properly![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
And add on 500$ for kira![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
I'm preparing to do this, but depends on a few things
I called sonicms:
Total: $500
Total: $160
#47
lol its so worth the money, coilover are so stiff and SOOO FUNN
is like you have having gay **** hardcore sex riding on bouncing HARD UP AND DOWN THE WHOLE TIME and you actually enjoy every second of it and you will scream
FASTER FASTER HARDER!!!!!!![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
#50
Moped
DIY Suspension = $30 for beer lol!
Hotel for the weekend and pocket money maybe $400 (its a tedious job and i cant not just make the turn around)
then the 500..
simple but impossible for now.. thats why if you do end up finding your stock and swap them yourself ill pick them up right away.
