Someone with a C sedan help me
GL450, Sienna SE
Can someone with a C240 preferably or even a C320 go into their trunk. Open the fuse box on the left side and tell me if there is a 15 amp fuse. Its blue and if you have it, can you tell me the location. Just count where the location is from the top or bottom of the row of fuses. Thanks.
2002 C240 Classic
why don't you get the fuse map and see exactly where it goes. its located on the drivers side.....when you open the door you will see a panel near the steering with a small indent on it. pull the plastic off and its inside (i think there is also another fuse box in there)
