Car is buried under 12 feet of snow... *pic*
Old Feb 18, 2003 | 03:22 PM
02Impressor's Avatar
2008 E 350
Errrr... is it warm under there?
Pic was taken 24 hrs ago (3:30 on the 17th). Snow is double the size now.
Old Feb 18, 2003 | 03:23 PM
BrabusCClass's Avatar
GL450, Sienna SE
Got a pic? Its sunny here about 80F.
Old Feb 18, 2003 | 03:24 PM
2008 E 350
just added pic above
Old Feb 18, 2003 | 03:25 PM
tifosiv122's Avatar
SLS AMG | S65 AMG | GL550
Re: Car is buried under 12 feet of snow... *pic*
See here.
I think you mean 24 inches or 2 feet...12 feet would be over you garage.
Erik
Old Feb 18, 2003 | 03:27 PM
2008 E 350
Re: Re: Car is buried under 12 feet of snow... *pic*
Erik
It's more like 9-10 ft. 30" of snow was just the morning, after the shoveling (I had to clear pathway) all snow was dumped on car. It's roughly 9-10 ft now, no joke. In pic it's about 7 feet.
Old Feb 18, 2003 | 05:01 PM
pokerFACE's Avatar
Re: Re: Re: Car is buried under 12 feet of snow... *pic*
and why did u choose to burry your car?
Old Feb 18, 2003 | 05:38 PM
2008 E 350
Re: Re: Re: Re: Car is buried under 12 feet of snow... *pic*
Good question. My father had to get his car out the garage and out of the driveway. The 30" of snow was blocking that path so I had to shovel it to the side. My car is on the side. There wasn't anything I can do.
Old Feb 18, 2003 | 05:52 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
one word: WOW
one question: don't u have a garage?
Old Feb 18, 2003 | 06:00 PM
2008 E 350
Originally posted by FrankW
one word: WOW
Yeah it's taken up by the 2nd car. The other half is full of garbage that I have to sort through when it gets warmer.
Do you think anything can happen to the car if it stays like this for another 72 hours? There should be a heavy storm this weekend so hopefully it will melt most of the snow.
Old Feb 18, 2003 | 06:17 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
no idea other than for sure that you will have a hard time re-start your car. My suggestion is to let the snow melt by itself or hose it with warm water. NEVER scrape!
Old Feb 18, 2003 | 06:47 PM
Rick's Avatar
C230K Coupe/Orion/C4/C5/CD/AMG Spoiler/V60/TeleAid, 2 MGB's
Talking
Dude....the NY area is supposed to get more snow tonight and tomorrow!
The rain storm this weekend won't melt the snow...it'll just rain enough to crust the snow with ice.
Citron may be a hot color....but not hot enough to melt all that snow. Hope you enjoy your Benzcicle...lol
By the way....did you remember to close your windows and roof? lol
Old Feb 18, 2003 | 06:56 PM
Matt230K's Avatar
2010 C300 4matic
His car is white. It won't attract any heat at all. It will be a benzcicle.
Oops, you better go check. Just dig it out real quick to make sure.
Old Feb 18, 2003 | 09:16 PM
2008 E 350
LMAO. I actually feel soooo bad that the car is buried under that *** avalanche. I dug a hole real deep just so I can see a part of the back window. I have no clue as to how I'm going to un-dig the car.
Old Feb 18, 2003 | 11:32 PM
Outland's Avatar
2002 C230 Coupe(M111)
NEVER use warm water. Never put water on a car outside in this weather. You'll likely freeze the doors shut.
Just get in, start it up, let it run with the heater and defroster on full, get out and brush the snow off with a gloved hand. Anything that sticks to the car- so what. It will sublimate in bright sunlight or melt as the car warms enough to warm the metal body a little. I wouldn't be too anxious to get out on the road with it anyway...the C-Coupes ground clearance is way too low for anything but hardpack or 3-4 inches of fluff
Old Feb 19, 2003 | 12:08 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Talking
o2 Impressor patiently waits for the storm to end, and carefully removes the snow...
uh, wait, it's ALL snow!
Where my freakin car!
Gdmit!
Mom, have you seen Dad lately!!!!
DAD!!!!!!!
Old Feb 19, 2003 | 01:09 AM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
good thing yer washer nozzle aare heated
Old Feb 19, 2003 | 05:23 AM
moomeh
Guest
Posts: n/a
instead of clearing off all the snow from the car (which will then lead you to clear it off the driveway meaning more work), clear off most of the snow from the path the car will take if you were going in reverse. then floor it out the drive way and do a 90-120 degree quick turn to let most of snow fall off. that should clear the windshield as well. so drive 40-60 mph around for awhile make quick sharp turns. i'm assuming:
1. your a good driver
2. you aren't going to hit anyone coming out of the drive way
3. friends with local police
that should work...
Old Feb 19, 2003 | 04:32 PM
FInality's Avatar
996 Turbo
DO NOT drive around with ice on your hood. When it slides off it will leave DEEP clear coat scratches. I know because this has happened to me twice.
The first time I did not expect it to happen but the second time it slid off I never even realized it was loose it was frozen solid to my car just 2 hours before hand.
Best bet fluff out as much powder as you can from the car and wear some waterproof gloves. If there is a layer of ice on the car let it get a bit warmer and use a friend to lift the ice sheets of the car do not try to force it off...
Some friends of mine used hot water to remove all the ice from their car but I'm not sure how good that is for the paint with the extreme contrats in temperature.
Old Feb 19, 2003 | 04:45 PM
2008 E 350
Thanks for the tips guys. I think the easiest thing to do at this point is to just dig out the snow from the rear and on the drivers side a tad just so I can get inside. Then my plan is to backout of the mountain of snow. The thing is my driveway is not big enough to do ANY turns so I'll have to back up at a slight angle and then just go back out of the driveway ...that is, if the car starts.
Old Feb 19, 2003 | 08:47 PM
jnjrowland's Avatar
no matter what
Make sure that the exhaust pipe is clear if you are running the car for any length of time. If you don't you could end up with carbon monoxide build-up in the car.
JR
Old Feb 19, 2003 | 09:25 PM
2008 E 350
Re: no matter what
JR
Yeah I saw that on the news too, even though, its common sense. Anyway started digging poor car out today, got back done, the car is lowered (car is 10% lowered onto tire) because of all the snow on top. unbelievable.
