clear lights on front bumper
Old Aug 8, 2009 | 12:53 AM
kunal07's Avatar
2007 C230 manual
I was just wondering if it is definitley necessary to remove the front bumper in order to change the orange stock lights to the clear outs.
thanks
Old Aug 8, 2009 | 01:09 AM
gregr09's Avatar
non-MB
Simple, easy search brought up this.
Old Aug 8, 2009 | 01:59 AM
glocati's Avatar
2016 GLE 350
the whole lense assembly pops out. use a tape covered putty knife or something similar and start at the front and press the whole assembly towards the rear of the car while pulling the front out. The whole lense should come right out. If you go clear, you will need to get two amber 5 watt wedge bulbs. prettyy easy---just be careful not to scratch your paint.
Old Aug 20, 2009 | 11:37 PM
ntwillie1's Avatar
07 TL, 05 350z, 08 MDX
why wouldn't he be able to reuse the same bulbs?
Old Aug 21, 2009 | 12:14 AM
glocati's Avatar
2016 GLE 350
Factory uses a clear wedge bulb behind the amber lense. If you go clear lense and use the clear bulb, your side markers are not amber when lit up.
Each state is different, but they are suppose to be amber if you run front side markers.
Old Aug 21, 2009 | 10:23 AM
omg its nate's Avatar
06 C230 6 Speed FTW
I would get the chrome bulbs that flash amber.
Old Aug 21, 2009 | 11:39 AM
glocati's Avatar
2016 GLE 350
yea, even better. then you don't see the yellow egg yolk in the middle of the clear lense.
Old Aug 22, 2009 | 12:59 AM
ntwillie1's Avatar
Thanks for the explanation, much appreciated.
Old Aug 23, 2009 | 09:35 PM
draze's Avatar
2002 c230 kompressor M111 6spd
Where do I get the clear lenses and the 5W chrome amber light?
Old Aug 23, 2009 | 10:18 PM
ntwillie1's Avatar
ebay
Thats easy, go on ebay and get them. I've seen them for as low as $15 - $23. I haven't seen the bulbs as I wasn't looking for them but i'm sure you can get them there also although I'm fairly certain other members here now of bulb meccas to point you towards. Good luck.
