oil puff????
My car leaves a good amount of white smoke every morning, even in 75 F mornings at 7am, so im guessing your car is normal.
[i replaced both left/right valve gaskets and no im not burning oil, if any of you are wondering..]
Please remember that the rings constantly rotate in service. Now & again you get unlucky & all the ring gaps line up. A little bit of oil gets by and when you start the car after standing it burns this oil & you get a puff of smoke - Nothing to worry about.
The only time you should worry is if you run down a hill on trailing throttle & then accelerate & the engine blows a cloud of oil smoke it's a sign usually of worn valve stem seals or in the worse case rings. Usually the former.
If it's valve stem seals even that is not a train smash.
I think it was just ring gap line up. - Don't worry - just watch it for a short while. If you have any worries about a blown cylinder head gasket any good workshop can check your coolant for combustion by products.
Good Luck
