Where to get replacement ment climate control knobs?
The 4 climate control knobs on my w203 coupe are starting to look worn, and I would like to replace them as they just clip off.. I have looked on the EPC with no joy, do any of you guys know if they are available from mercedes without replcing the entire unit?
I'm really not one to spoon feed, especially to those with few posts (no forum contribution), because pretty much everything can be found using Google. But I happen to find these on eBay while looking for something else, and remembered this post.
http://cgi.ebay.com/ebaymotors/2001-...Q5fAccessories
It will not work on any 2005+ car.
nickgailloux: did alittle more searching on fleabay.. found cheaper ones at like 45USD.. just letting you know..
lilbenz230: thanx for the input! i pm'ed the seller asking for the part number so i can call the dealer. thanx again!
What I did was...I took the black coating, primed it,and painted it with flat black. Only you would know it's painted.
You can meticulously cover the white line "pointer" but I chose not to on mine.
For uniformity,you can do all knobs.
Good luck.
I need the knobs on the climate and also the radio.
If possible, also the tab on the vent.
All these rubber pieces are failing and seems to be either peeling / gumming up.
I can remove the climate knobs, but I don't know about the radio or the vents.
Anyone know how these gets fixed?
You see the white part? At first I thought those will lit up at night, but haha.. that was just a wish, although that would look nice.
Keep an eye out on ebay, best to buy the unit, sometime you get the console pieces with units attached, just but and resell the trim e.g.
http://cgi.ebay.com/ebaymotors/MERCE...Q5fAccessories
I think the knobs is failing from extreme heat. The sunshine we get here isn't too nice for these parts i suppose. Also on top of the protectant stuff we put on it might be a factor too. Somehow the chemicals in that stuff have decomposed the rubber or something.
Contact Steve at MBenzNL. He is the sort of person that might have access to one of the old knob kits. I don't know who made them.
Your knobs look painted or coated with something. My knobs are matt soft rubber finish
Some strange things happened with US cars. He also has the older radio than fitted in ROW for immediate pre facelift.
I wonder where that car was built? Brazil?
Center console armrest is just a given.To be fair his controls haven't disintegrated like I've seen some 2001-2002 cars do.
BTW - Meguiar's Scratch X does a good job of polishing out minor scratches in your post facelift "sexy" radio face.
Pleased I have a local armrest - It's fine.
People here have chrome peeling problems on some post facelift dash bits.
Something is wrong with these knobs. I also notice this on the steering controls too. It's starting to dry up then gets gummy and becomes gooey. I end up having to clean the area noticing sections of the once used to be rubber is not longer there.
