P0237 code/Lack of power
So when I got the code again recently, I assumed some hose popped off again. I looked around and seems as though all hoses are secure. Is there anything else I should be llokng at?
I have a 2005 C230 with the M271.
Picked up a 2005 c230 with 101k miles for a pretty good price. Need some work which Im willing to put in. When I bought it, couldnt hear any SC whine/noise/life at all. And very slow acceleration at all speeds. Smooth idle, starts/fires right up. No smoke from tail pipe. CELs were p0237, p0410, and p0171.
After purchased, did the recirculation reset via STAR for the SC, Cleared the codes, drove and at mild to moderate throttle, still sluggish but no CEL. CEL light only came back on after full throttle run and only the P0237 code. I removed and carefully checked the supercharger hose that goes to the EGR valve, but it was snug and I saw zero cracks/rips/tears at all.
Any suggestions on what areas to focus on next for troubleshooting? Really seems like there must be an air/vacuum leak somewhere based on the CEL light not coming on until I went full throttle.. And its repeatable. If I reset the CEL, it stays off and only comes on again after I hit full throttle.
Tips? Goal is to fix this as cheaply as possible myself. Thanks.
Then removed and cleaned throttle body well. No change. Did a smoke test. No signs of any vacuum leaks. Replaced the MAF. No change. Replaced air filter. No change. Replaced spark plugs. No change. Filled up with full tank of premium and techron. No change.
Upon more observation, noticed the following. After clearing the code, the car may run well for a few miles. Perfectly smooth, nice pull, perfect idle, etc. And NO cel. What triggers the CEL every time, is at moderate throttle when accelerating from a stop or slow speed, right at about 2700 rpm, there is a slight 1/2 second hiccup. Thats when the CEL gets triggered, and then the car continues to run totally fine.
WHat could be triggering that hiccup? And that hiccup has been there before I replaced anything, and remains after I replaced all the above.
