need help.. weird issue that i never heard of..
Old 10-06-2009, 01:56 AM
skittles's Avatar
Moped
bump.. a little help please... i wanna get rid of this problem...
Old 10-06-2009, 05:46 AM
W203E35's Avatar
2006 C350 Sport 6MT
I remember you said you get vibrations from your left and also it pulls to the left. Check this out and inspect to see if it's loose. In the meantime I will try to see if there are any issues with oil leaking out.
Old 10-06-2009, 05:51 AM
W203E35's Avatar
2006 C350 Sport 6MT
It might also be the CV Joint. Here is a pic of a damaged CV Joint (Before/After)
Before
After
I strongly believe this might be your problem. At high rates of speed the oil/grease from the CV joint is squirting onto the wheel. At high rates of speed the grease is escaping from the gaps of the wheel cap.
Inspect the CV Joint. Check out this site it shows how to change. Although not for Mercedes but same procedure.
http://www.wallpaperama.com/forums/how-to-replace-front-cv-joint-axle-repair-install-remove-wheel-drive-boot-t442.html
Old 10-06-2009, 04:47 PM
W203E35's Avatar
2006 C350 Sport 6MT
Any updates? Were you able to find out what the problem was?
Old 10-06-2009, 05:42 PM
glocati's Avatar
2013 ML350
Looks to be a non-4matic car, so should not be a CV joint.
Old 10-06-2009, 06:12 PM
W203E35's Avatar
2006 C350 Sport 6MT
Ohh..You're right it's the front
In that case it's got to be the front hub or front wheel bearing.
Old 10-06-2009, 08:24 PM
  #32
skittles's Avatar
Moped
aye ah! inspected my front left this AM before going to work. and yeah i was like, what the?! it looks so diff.
then now i read your messages.. that only the 4matic had these.
so how do i know if its the hub or wheel bearing? so the oil came from one of these parts??? and this is what makes my esp go crazy?
EDIT: could this also be the problem? https://mbworld.org/forums/c-class-w...placement.html
Old 10-06-2009, 10:11 PM
  #33
W203E35's Avatar
2006 C350 Sport 6MT
That's all I personally can think of at the moment.
Was this on the left or right side? So there was no residue on the wheel? Is it possible to be power steering fluid?
It's hard to tell what it might be. The grease looks like it's not dirty like the stuff on your wheels. Maybe it was something on the road (highly unlikely but possible).
For the vibrations it is highly likely it is your bushings. Also maybe you need an alignment too.
Do you see anything wrong with the suspension area? Any leaks? Check the bushings too.
If you want you can come by this weekend and we can jack up the car, take off the wheel and see what it is.
Old 10-06-2009, 11:11 PM
  #34
skittles's Avatar
Moped
yeah.. i might take that offer. although. i had just replaced all bushings, got my coilovers so i also just got an alignment done recently.. im really starting to think its the hub or bearing.. if i were to go this weekend id love to bring parts along so we can do a DIY and fix this problem..
if no solution online i might as well go there this sat and lets take a look together..
Old 10-06-2009, 11:17 PM
  #35
Racerx18691's Avatar
Mercedes ML430
someone please help
can u please tell me how to post a question so that everyone can see and answer? I can not find a link to post a question anywhere on this site. thank you
Old 10-06-2009, 11:25 PM
  #36
skittles's Avatar
Moped
when your on the thread menu. ontop of all the topics on the upper left there should be a button for new thread.
Old 10-06-2009, 11:35 PM
  #37
e1000's Avatar
a quarter mile at a time
you should separate the C and the L in that pic.
Old 10-06-2009, 11:38 PM
  #38
skittles's Avatar
Moped
hahahaha! just trying to help a soul. for him.. ey man what you think the issue on my car is?
Old 10-07-2009, 12:53 AM
  #39
e1000's Avatar
I'm really not sure to be honest. It could be an electronic gremlin or it could be something mechanical we haven't found yet. Is it storing any codes?
Old 10-07-2009, 01:03 AM
  #40
skittles's Avatar
Moped
no codes at all.. grrr...
Old 10-07-2009, 01:04 AM
  #41
W203E35's Avatar
2006 C350 Sport 6MT
Bring it by this weekend. We got the WIS so we can make anything work
Just let me know when you are coming because on the weekend I tend to wake up at 1:00 PM (got to set the alarm extra early and if I don't come knock on my door you know my pops so it's all good)
If you did the bushing an alignment then we'll inspect the front hub and bearing.
Old 10-08-2009, 01:19 PM
  #42
skittles's Avatar
Moped
ok so buddy i gotta see you this weekend man.. this ONLY happens when it gets cold outside. like i can make this issue wait then when it hits summer this ESP problem is gone. then winter its back again. is the wheel speed sensor Glocati's talking about sensitive to temp??? the grease/oil and vibration im pretty sure is one of the bearing or hub so that we can solve on sat.. dunno about this ESP. in the other hand the door locks creeping out on me is gone. that link erick gave me, gave me an idea. i emptied my trunk of junk and it never did it again. hahaha. it had to do something with hitting something. anyway whats up with the temp issue?
Old 10-08-2009, 06:14 PM
  #43
W203E35's Avatar
2006 C350 Sport 6MT
Ya, come on by this saturday. If you want get some brake fluid and we can change it this weekend as well.
Old 10-08-2009, 06:32 PM
  #44
e1000's Avatar
you guys need my pressure bleeder?
Old 10-08-2009, 07:09 PM
  #45
W203E35's Avatar
2006 C350 Sport 6MT
I have a pump for the oil (oil extractor) i'm thinking of hooking up a tube to the original tube and buying this
Then drilling a hole and putting the tube in there and sealing it with a hot glue gun.
I got the idea through this:
http://www.bmw-m.net/TechProc/bleeder.htm
Old 10-08-2009, 07:32 PM
  #46
skittles's Avatar
Moped
cool idea! anything goes man. so wait. i remember erick said we use DOT5 brake fluid. when i inspected my fluid the cap said DOT4. is it ok to put in DOT5? ill get all the stuff i need for sat.. ill try to get new rotors also. my pads are still new.. incase we do find out what the problem is. is there a parts place close to you where we could get some parts?
Old 10-08-2009, 07:34 PM
  #47
e1000's Avatar
DO NOT USE DOT5!!!!!!!!!!!! Use DOT4 or DOT5.1 (4+) DO NOT USE DOT5!!!!!!!!!!!!
Old 10-08-2009, 07:35 PM
  #48
e1000's Avatar
You can use your extractor as a vacuum bleeder, but then you don't need a modified cap. Otherwise, just borrow my pressure bleeder.
Old 10-08-2009, 10:18 PM
  #49
skittles's Avatar
Moped
so hold on erick.. i cant use DOT5 but i can use DOT5.1??? ehhh???
Old 10-08-2009, 10:33 PM
  #50
W203E35's Avatar
2006 C350 Sport 6MT
DOT5 is silicon based fluid that's why you can't use it.
Quick Reply: need help.. weird issue that i never heard of..
