Removing map light?
Old Oct 7, 2009 | 02:35 PM
fanaduck's Avatar
2005 mercedes C230 Kompressor Sedan
Removing map light?
I have a 2005 C230 Kompressor Sedan. How do you remove the plastic covers on the map lights without breaking them? I already removed the main dome light, but the map light plastic just doesn't want to budge. I'll get one corner almost popped out then when I try to work around the other corners it pops right back down. Please help
Old Oct 7, 2009 | 02:54 PM
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
i had the same problems! i ended up slightly breaking one so i pushed them back in and gave up!
Old Oct 7, 2009 | 02:58 PM
krisv420's Avatar
02 C320 Sedan
I almost did that to mine.. to scared to mess with it anymore.. But i think there is a small fly inside mine.. BLAHH
Old Oct 7, 2009 | 03:04 PM
fanaduck's Avatar
Well, i'm not giving up. i'll update you guys when/if I break mine. hopefully i'll get some pics up with the LEDs installed
Old Oct 7, 2009 | 04:26 PM
XsuperbeeX's Avatar
C320 coupe
its the one on the sun visor or the one in the middle??? if its on the sun visor just pop it... if its in the middle you must take out the bulb from the inside... so pop the unit open... it's easy... starting from the dome light then push the two metal pins thats it...
