3 Malfunctions displayed on my dash..
Old Oct 25, 2009 | 01:58 AM
C230 MB's Avatar
2003 Mercedes Benz c230k
Arrow 3 Malfunctions displayed on my dash..
I was on park and just listening to my radio for about 20 minutes... and when I started the car, 3 malfunctions displayed on my dash. ABS system visit workshop, ESP not available and BAS brake assist not available. I started driving the car and have noticed the car won't go as fast as I step on gas pedal and RPM was higher. It also felt like the car will stall at stop too.
So I drove it for about 4 miles thinking maybe it needs to recharged the battery. I let car the cooled off for about 45 minutes , and when I started the car again , 3 malfunctions was gone and the car was back to normal. Any concern that I need to worry about? battery, alternator... need your opinion, I drive an '03 c230K. thanks, Paul
Old Oct 25, 2009 | 02:15 AM
acr2001's Avatar
2012 C300 4Matic
How old is your battery?
My best guess is either it's going, or you ran it pretty low. Strange though, because the car shouldn't allow you to run it down, it's supposed to warn you and turn the radio (and other accessories) off until you start the engine.
Old Oct 25, 2009 | 02:27 AM
C230 MB's Avatar
I'm the second owner.. I can ask the previous owner a friend. I'm assuming the battery is the original. The car has 70k miles... most car if the battery is weak, they won't start at all. thanks
Old Oct 25, 2009 | 04:30 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
The later model C-class cars warn you of low battery voltage and tell you to "START ENGINE". If the battery is original, though, it was time for it to go.
Old Oct 25, 2009 | 09:33 AM
Glyn M Ruck's Avatar
Super Moderator
Something triggered limp mode. A reboot by restarting the car seems to have corrected it. Might just be a one off ECU glitch.
Old Oct 26, 2009 | 03:32 PM
C230 MB's Avatar
My MB mechanic told me it could be the brake lamp switch...but to be sure he needs to run some test...plug in his computer into car and see what the readings.
Old Nov 1, 2009 | 03:01 AM
99210's Avatar
1999 e320
battery maye go to low and steering angle sensor denormalized//to normalize have car running and trun steering wheel lock to lock
Old Nov 1, 2009 | 04:07 PM
Arn560's Avatar
Black 04 C230 Kompressor SS
I had the same thing happen to me but my car was moving at the time. When I stoped & reatarted the engine the message went away, I was told on the forum it might be a brake switch the may need replacing. Elswhere on the forum it syas the switch is located under the brake pedal but there is nothing under mine so I don't know which model they were referring to.
