Power Steering Reservoir location 05 C230 Kompressor?
C230 Kompressor
Where is the power steering reservoir for 05 C230 Kompressor Sedan 1.8L? Is it the boxy black reservoir next to the coolant reservoir on the passenger side? I have a feeling it is, but I want to make sure it is before I top it off.
Yes, that is the power steering pump/reservoir on the upper right side of the engine.
C230 Kompressor
Thanks Paul. I plan on topping it off tomorrow. It is currently low. My car occasionally makes a whinning/squeaking noise when I turn right to park or reversing. I hope this will fix the problem.
I highly recommend that you take it in and check for leaks before you top it off. I recently had to replace my entire steering rack because my P/S pump was leaking into it and ruining the seals. it wasn't a cheap fix
