DDM Tuning HID's $30!
Old Jan 28, 2010 | 12:45 PM
  #151
emanresu's Avatar
C240
Originally Posted by jcnash
Do you have daytime running lights? If you do, the errors may show ONLY when running in DRL mode.
No DRL unless they are those 194 wedge city lights. Is the DRL mode the same as the Auto setting?
Old Jan 29, 2010 | 01:22 AM
  #152
bdgdl08's Avatar
1999 CLK320 (sold), 2007 C230 SS (gone), 2000 Grand Marquis, 2011 CR-Z, stay tuned...
Originally Posted by emanresu
I just got my kit in the mail. Once installed, I noticed one of the ballasts creating a buzzing noise with the lights on. Is that normal or is it a sign of a defective ballast?
Also, the error with the lights never came on without the error eliminators installed, but I put them in anyway. Does the error show up only when the car is running?
Yes, you will only get an error when the car is running. As far as DRLs go, that's the Headlights = Constant/Manual. If they're set to present, then you have DRLs. All the DRL setting does is run the regular halogen low beam H7 bulbs at lower wattage so they are dimmer. It also doesn't run any other light other than the two low beams. If you get your Xenon setting set to present, the DRL runs just the two low beam lights at full wattage.
Old Jan 29, 2010 | 09:19 AM
  #153
jcnash's Avatar
2002 Mercedes Benz C230 Coupe
hey guys,
What is the difference between the 55W
APEXCONE RAPTOR HID KIT and the 55W DDM HID KIT SLIM BALLAST kit? Is the only difference the size of the ballast or are there any other differences/advantages of one kit over the other.
Also, has anyone bought the error eliminators and returned them because they weren't needed? Did DDM refund and pay for shipping etc?
Thanks.
Old Jan 29, 2010 | 05:56 PM
  #154
emanresu's Avatar
C240
Originally Posted by bdgdl08
Yes, you will only get an error when the car is running. As far as DRLs go, that's the Headlights = Present/Manual. If they're set to present, then you have DRLs. All the DRL setting does is run the regular halogen low beam H7 bulbs at lower wattage so they are dimmer. It also doesn't run any other light other than the two low beams. If you get your Xenon setting set to present, the DRL runs just the two low beam lights at full wattage.
Thanks, I checked it out. To be exact, my speedometer screen has the setting "Headlights = Manual / Constant"
I contacted tech support and they said the buzzing will go away after a week or 2 of normal use.
Old Jan 29, 2010 | 08:36 PM
  #155
bdgdl08's Avatar
hey guys,
Thanks.
The difference is the size, but I can't speak for the quality of the Raptor ballasts. They're guaranteed, so I don't see any problem with getting them. I got my setting changed, so I not longer need the error eliminators. For that matter, if anyone needs error eliminators I've got mine laying around.
Sorry, I meant Constant. I was thinking about the Xenon setting. I'll have to check if mine still buzz at all. I think they do still when they are warming up.
Old Jan 29, 2010 | 11:04 PM
  #156
emanresu's Avatar
C240
So it is the DRL setting, the wattage of the HID kit, and the Xenon=present issue that determines if you really need the error eliminators?
I am beginning to think that the error eliminators that I bought are of no use now that I got the 55w kit and have always had DRL turned off. Too late to return them now.. But what about a set on the fog lights? They wouldn't need error eliminators right? 35w HID replacement for 35w fogs makes perfect sense.
Old Jan 29, 2010 | 11:14 PM
  #157
bdgdl08's Avatar
As far as I know, needing error eliminators depends on either the Xenon=Present setting... or dumb luck. I needed the eliminators until I got the setting changed. Matt, on the other hand, didn't. I don't know if the fogs need error eliminators. Someone else will have to answer that. I'm sure DDM would take the return, but I don't know. Mine are still sitting in my glove box.
Old Jan 30, 2010 | 02:00 AM
  #158
jcnash's Avatar
Ordered the 55W Raptor kit with a pair of error eliminators. Shipping to Ottawa, CA will take till Feb 8 . Ill keep you guys updated on if any errors are thrown during night time or DRL operation.
bdgdl08, I might be interested in your error eliminators for my other car. Ill let you know once I get a chance to try out the ones Ive purchased.
Old Jan 30, 2010 | 10:28 PM
  #159
bdgdl08's Avatar
Sure thing! Good luck getting your kit. I hope you like it.
Old Feb 2, 2010 | 03:37 PM
  #160
pope2001's Avatar
I have a 2002 coupe. I ordered a xenon kit over a year ago from DDM. I got the 35w 6000K for my headlights. I also had to order the error eliminators. Once installed the lights would flicker. I had to make a trip to the dealership to have them seet the headlights to xenon present. Lights have worked perfect for over year with no problems. They look great and are super bright.
Old Feb 2, 2010 | 05:17 PM
  #161
jcnash's Avatar
So even the flickering is caused by the Xenon present setting not being set correctly? Why did you need the error eliminators?
Old Feb 2, 2010 | 06:41 PM
  #162
londonbenzkid's Avatar
2002 C240, 2006 ML350, 2011 X3
Note to Canadian Buyers:
UPS charges a brokerage fee of 30$ regardless of duty fees.
Duties to Canada was $0, GST tax was 8.25$ and the brokerage UPS SCAM FEE* was 29.95$ plus they charge GST tax on the brokerage fee... total: $39.92 CDN
Other shipping companies have never charged close to that amount, at most I have paid for these brokerage fees is $5-10 for similar packages in value.
Unbelievable.
DDM should ship with USPS or anything other than UPS for CANADIAN orders as they basically rob you with this brokerage fee.
Old Feb 2, 2010 | 10:31 PM
  #163
jcnash's Avatar
UPS is a bunch of ****ing *******s. Hate those *******s...every one of their customer service reps has like sworn an oath to stupidity or something...
Old Feb 2, 2010 | 11:11 PM
  #164
i agree jcnash..
let me know what they charge you for the brokerage and duties
I swear we need to boycott this company.
i understand that in the US, UPS is actually very fast and stuff, but they rob you when your a Canadian customer.....
Old Feb 3, 2010 | 07:00 AM
  #165
91RS's Avatar
2016 Chevrolet SS, 2006 Cadillac STS-V
Originally Posted by londonbenzkid
i agree jcnash..
They're not any better here. I referr to them at UPS (pronounced OOPS) and the United Parcel Smashers. I like FedEX. Never had a problem with them.
Old Feb 3, 2010 | 09:44 AM
  #166
jcnash's Avatar
i agree jcnash..
Will do. Im expecting the package to arrive on Feb 8. Theyre probably going to charge me 30 bucks +_ the customs duty which i expect is about $10-13. So Overall I will be paying about 50% of the cost of the item in duties and fees and such. Thats ****ing bull****.
Old Feb 3, 2010 | 05:48 PM
  #167
Its 100% bs, I am installing my 8000k 55w slim digitals this sat, I'll let you know how they are. I got my xenon-=present set at my independent with a snap on modus.
Old Feb 3, 2010 | 11:41 PM
  #168
jcnash's Avatar
I might bug you soon for some more info on this. The stealerships here want almost $200 to change this setting, so if theres a cheaper way..why not?
Once I get my HID's Im going to try to see if the error eliminators fix the problem...if not I might have to resort to this. How much did it cost you?
Old Feb 3, 2010 | 11:45 PM
  #169
bdgdl08's Avatar
I got mine done at my indy for free. You should be able to find somewhere to do it.
Old Feb 4, 2010 | 12:29 AM
  #170
lbmazdaspeed's Avatar
2009 c300 4matic P1
hi, guys
I just had a quick question if my car headlight setting shows Manual/Constant. will I be ok with just putting the eliminators, or will have to get the dealer to do the present change, cause i dont want to go to the dealer and have them change the present cause my benz dealer is pretty dumb.
Old Feb 4, 2010 | 12:33 AM
  #171
bdgdl08's Avatar
If you just set that setting to manual you will be fine with error eliminators.
Old Feb 4, 2010 | 12:44 AM
  #172
2009 c300 4matic P1
cool thanks im exited to get them i will post some pics when i have them on, i never had hid lights before on any on my cars, but i think is about time i start getting them,
thank again
Old Feb 4, 2010 | 07:02 AM
  #173
91RS's Avatar
$200? Wow, my dealer charged me $61 to change Xenon and a few other settings.
Old Feb 4, 2010 | 09:46 AM
  #174
jcnash's Avatar
Yeh the dealers here suck. When I went to inquire, he told me some horse**** about how the star computer costs 35 g's so it depreciates every time a car is plugged in, so he has to charge me the minimum labor fee + computer usage fees etc. even thought he actual setting change will take all of 5 minutes!
There are only 2 dealers in Ottawa, so they know customers have nowhere else to go. LOL. Im going to be in Toronto soon, so might get it done there, or try with an indy as bdgdl08 suggested.
Old Feb 4, 2010 | 03:11 PM
  #175
since i regularly go to my indy to service my C240, we have a pretty good relationship so he did it for free.. but if you are paying for this xenon option set, then tell the dealer to suck a big one... and go to an indy with a snap on modus or star diag system and pay him like half an hours worth of labour like 40 bucks
