Paging MB techs and gurus for brake problem!
The other possibility, and this happens only when I got to American Tire, they overtighten the lugs and that warps the rotor. But you would have noticed that right away, not a month later.
This issue is inherently prominent on Mercedes Benz's due to caster angle (notice the small turning radius and weird tilt when wheel is turned).
You can tell if this is the issue if after braking or hitting a bump that the steering wheel vibrates at a low to mid frequency (earthquake feel) which will go away only after significantly slowing down.
This use to happen to me on numerous models. Might be worth just checking if not resolved.
Regardless, it's hard to warp the rotors even with aggressive driving on these cars. These symptoms I have experienced on 116, 126, 201, 124, 210, 211, 140, 220, and 221 chassis especially once tires were old, weights came off, or even new and not dynamically balanced. I spent much on replacing rotors, and all were cured by dynamic balancing.
Any time I think of Honda, I remember the cup holders in the Civic:
Proof that their engineers are idiots?
Either way, round block no fit into square hole!
Honda engineers never made it through kindergarten
lol the cup holders in my civic were larger then my c32. I had 5 cup holders...two 32oz and 3 16oz cup holders.
Either you havent sat in a civic in the last 5yrs or your off base..
back to topic.
Sorry, didn't mean to hijack the thread.
I did a complete front brake job on my C230 @ 53,000 miles. New rotors, new OEM pads, fluid flush. By 57,000 miles, the rotors seemed warped. I got vibration/pulsation in the wheel and pedals during normal stops. I was furious and, though I'm too lazy to, you can probably find some posts on this forum about it. I did the bed-in procedure three times to no avail. I also did a very abusive session with the brakes, pushing them to fade then beyond to up in smoke. None of this made the stuff go away.
7,000 miles on the new brakes @60,000 miles and the vibration was gone. At 67,400 tonight it has not returned. Nothing changed, the tires are the same, no alignment has been done.. it just vanished. I can't explain how it might have happened, but it did.
Some people say ceramics fade faster during hard braking, but i havent noticed my brakes fade. My tires gave out way before my brakes have so far.
Tires are brand new, road-force balanced with no vibration at speeds. all the balancing weights are on and the car is smooth at all speeds until braking. this is not a tire issue. but thank you for your input
1)So, the dealer has said they checked runout on hub and rotor. Did they do this prior to replacing the "warped rotors"? What I am getting at, is did they verify the rotors were truly warped?
2)I assumed they used OEM pads as replacement?
There are many cases where brake shimmy and pulsation are misdiagnosed as warped rotors, when they are not truly warped. Uneven pad material transfer from the pad to the rotor happens very frequently, and this is often the case for misdiagnosed warped rotors. There are a number of causes and different ways to fix it based on them. Please read this article and follow the recommendations and report back: http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Matt's post above is another indicator of what I think may be going on in your situation.
Also, pics of the rotors would really help to diagnose further.
yes, i could rebuild them for a lot less money, however, at this point i have spent way too much money diagnosing this problem to still have factory brakes. although the sport brakes are very good, they just don't have the braking power that i need to insure proper and consistent braking, at any speed or any situation. even though i spent a fortune on rotors and diagnosis, the extra $2000 for stop techs will be worth it for peace of mind and will have more than enough braking strength for my current mods, and the mods to come. i have been considering upgrading the brakes for awhile, but now i have incentive.
My 135i has 6-piston fronts and 2-piston rears, huge brakes for such a tiny car. The feel is a bit better but they don't seem anymore capable than the C230s, and I drive the crap out of both of these cars.
How much power are you pushing from your C230, anyway? My 330hp 3700lb G37 coupe had the standard 2-piston sliding calipers!
i don't know how much power im running as i haven't dynoed yet, but i am working on a bi boost system utilizing a remote gt28rs turbo with the OEM blower and standalone fuel management system; so i'm also trying to plan ahead. should be a fast car when its all set and done, and ill definitely need bigger brakes for the track!
i guess all in all, i have abused my stock brakes for almost 5 years, and more recently, i could never get them to feel good, like they used to. maybe my opinion on them has been jaded a little by the problems ive had with them, but the way i look at is, it can't be a bad thing to put a well-balanced 4 pot system from stop tech on the car right? whether i stop that much better or not i guess ill find out, but it does give me peace of mind if nothing else (plus they look really nice too!)
i'd also be willing to sell the calipers to someone to rebuild as an upgrade to their stock system, at a very cheap price.
