C7 Package for C Coupe
Old Mar 9, 2003 | 08:36 PM
born2drive's Avatar
2002 C 240
Do aluminum pedals included in this package? If so, does anybody know the part numbers for these pedals? I'm trying to get it from the dealer but I need the part number just in case they don't know about it.
Old Mar 9, 2003 | 08:44 PM
Matt230K's Avatar
2010 C300 4matic
Yes, aluminum pedals are included in the C7 package. I doubt you'll find the part numbers here, buy you may get lucky. The best thing to do is go to the dealer. They should know what you are talking about. Or go out to their lot and find a c-coupe that has the pedals. Write down the VIN and have the parts department put that in the computer. It will tell them the parts that go on that car.
Old Mar 9, 2003 | 09:08 PM
.elijah.'s Avatar
W203
fitting for C240?
Do they fit for the C240 auto? tell me as soon as you get them...i'd like a pair!
Old Mar 9, 2003 | 09:28 PM
born2drive's Avatar
2002 C 240
They're only for manual transmission..????
hmmm......can somebody verify this.....
Old Mar 9, 2003 | 09:47 PM
slcvr6's Avatar
Awaiting a new arrival...
C7 equipped cars with automatic get versions of the pedals that fit the enlarged brake pedal and use the same gas pedal assembly. So, they should fit, the brake cover should be orderable, but I believe the entire pedal assembly is required to get the gas pedal.
Old Mar 9, 2003 | 11:16 PM
columbus's Avatar
'05 c240 4matic wagon
yeah, and the SL parking brake pedal pad fits the Coupe's parking brake pedal, in case the cheap looking rubber pad bothers anyone. It's about 8 bucks.
Old Mar 10, 2003 | 02:53 AM
born2drive's Avatar
2002 C 240
the parking brake pedal is only 8 bucks....???
So are there any difference between the C7 package pedals and SL pedals?
Old Mar 10, 2003 | 09:32 AM
Matt230K's Avatar
2010 C300 4matic
The rubber nubs are oval on the SL pedals and round on the C7. That's about the only difference, but the parking brake pedal still looks like it matches the C7.
Old Mar 10, 2003 | 11:30 AM
tifosiv122's Avatar
SLS AMG | S65 AMG | GL550
Here are pics of the SL pedal and the C7 pedals (sorry they aren't together)
http://www.eden.rutgers.edu/~ferrari...e/DSC00366.JPG
http://www.eden.rutgers.edu/~ferrari...e/DSC00309.JPG
Erik
Old Mar 10, 2003 | 01:59 PM
born2drive's Avatar
2002 C 240
I went to the dealer just now and they said the gas pedal cost about $100.....
Is that the right price...??????
BTW...the brake pedal is about $20. I'll try another dealer and get the part #s
Old Mar 10, 2003 | 02:12 PM
trench's Avatar
2002 C230 K
This is because for the gas pedal you have to change the entire pedal assembly, not just slip off the old cover and then slip on a new one (which is all that is required to change the brake/clutch/e-brake pedals).
- BT
Old Mar 11, 2003 | 02:19 AM
Class C's Avatar
W203
look at this previous thread for the C7 auto pedals.
https://mbworld.org/forums/showthrea...threadid=31728
Old Mar 11, 2003 | 06:12 PM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
YES, that IS right...but get yourself a gaspedal out of the SLK (approx 15USD) and swap the rubber on your current gaspedal (with the help of some soap) after taking out the locking pin in the top of your pedal (no tools required...5 minute job).
Swapping the SLK/W203 gaspedal rubber is doable and cheap...Jay did it himself in his C-class (pictures in linked thread above).
greetingz,
