WHERE GEAR SHIFT ATTENTION TO CONSOLE
Old Dec 6, 2009 | 01:28 PM
ChuckinTucson's Avatar
2012 S63, 2013 E350 Bluetec
Hard to explain, but where my gear shift attaches to the console, there is a chrome ring around the PRND and Shift Mode selection botton. Anyhow, this whole unit is loose, so when I shift from P to R for example, the whole thing moves. What is the best way to reattach this to the console?
I'm sure I haven't explained my problem very well, but I hope you get the idea. Thanks.
Old Dec 6, 2009 | 02:09 PM
RW C55's Avatar
'10 E63 Obsidiant Black; '06 R350 Alabaster White; 05 C55 Obsidiant Black (sold)
It sounds like the taps securing the trim are broken. You can follow the instructions in this thread and check and if they are broken, you probably need to get a new one.
Old Dec 6, 2009 | 02:26 PM
ChrisBrown's Avatar
2005 C240 4MATIC, 2020 GLC300 4MATIC
If it is broken, the new part is $150 or so. You can get it online wholesale for a bit cheaper. Every now and then there is one on ebay as well. It's pretty easy to install yourself.
Old Dec 6, 2009 | 02:56 PM
acr2001's Avatar
2012 C300 4Matic
I had this problem with my shift surround. The stealer broke one of the clips. I was able to put a small piece of double sided tape where the clip was, and then press down wedging it in where the clip used to be. Still holding, believe it or not, and you can't see it.
Old Dec 6, 2009 | 06:01 PM
howardyudoing's Avatar
07 c230 sport
that's what i did, but for all the clips even the ones not broken. fits snug
Old Dec 6, 2009 | 09:10 PM
As usual, this board's members come through. Thank you all for your replies.
