Help, c240 wont start
Old Dec 7, 2009 | 11:34 PM
victorb623's Avatar
c240
Help. This morning, I dropped by an independent dealer to check the color of my tranny fluid. Upon inspection, it was on the low side so the mechanic topped off my transmission fluid. Drove it for a mile and stopped to load up gasoline. When I started the car, CEL came on and it took like 4 secs to start. So I drove it to my school which is 40 miles away with CEL on and nothing different in while driving it (CEL on). When I arrived, turned the engine off then started it, CEL came off. everything is normal and drove home (40miles again) nothing unusual.
As I arrived home, I had a quick dinner then wanted to go to a supermarket.
I started the car, and it wont come to life. Tried it 7 times, it cranks strong so its not the battery? would any of you guys know what the problem could be?
Am freaking out. MB is not a reliable car
Old Dec 8, 2009 | 01:54 PM
holycaoAMG's Avatar
A Car
Get ahold of OBDII scanner, check for codes.
Most likely CPS [crank shaft position sensor]. They go bad around ~80k miles. GL
Old Dec 8, 2009 | 07:39 PM
victorb623's Avatar
c240
thank you for ur tip. I had it scanned and its the CPS sensor A. I ordered the bosch online for 40 bucks only! Would anyone know how to install this? Is it easy?
Old Dec 8, 2009 | 08:23 PM
Glyn M Ruck's Avatar
Super Moderator
Here you go - bit of a stretch.
https://mbworld.org/forums/c-class-w...PS+replacement
Old Dec 8, 2009 | 09:19 PM
Mu9enx's Avatar
01' C32o
Wow, 40? Awesome! It cost me 115$ for the CPS
Old Dec 8, 2009 | 11:09 PM
holycaoAMG's Avatar
A Car
^ that is cheap. Its funny, I have two extras on my desk right now too.
Old Dec 9, 2009 | 12:43 AM
victorb623's Avatar
c240
yeah, got it in http://www.autohausaz.com/ Bosch brand and its on sale from $132 down to $40.81
Once I get it, am going to let someone to install it. From the CPS thread, its hard to install it. Maybe 25-35 for installation is pretty good, what you think?
Old Dec 9, 2009 | 01:38 AM
Mu9enx's Avatar
01' C32o
It's tricky, but that's what I did. I knew where it was, but I didn't have the tools that allowed me to reach and unscrew the thing. I just took it to a mom and pop's mechanic shop and they help me unscrew and screw the CPS. Charged me $15, but I tipped them because of all the frustration they saved me, lol.
Old Dec 10, 2009 | 01:44 AM
victorb623's Avatar
c240
Yeah, This morning I wanted to check out and see the CPS. I couldnt see it...Will let a mechanic do it...
BYW, my car is okay for two consecitive days, no problems whatsoever, just a day of problem (monday). I trust the OBD II scanner. Will replace the CPS once the package arrives. Hopefully tom morning
P.S. Engine is M112. CPS code is PO335 (from OBD II scanner)
Old Dec 10, 2009 | 06:57 AM
Super Moderator
Yes - once they give trouble once they don't get better - Only a matter of time before total failure.
You are wise to replace immediately. Better than getting stuck at the roadside.
Old Dec 10, 2009 | 11:40 PM
victorb623's Avatar
c240
Finally I got the sensor today. I hope My mechanic will be available tom morning. Installation is $35 bucks only.
Anyway, just an update, 4 days straight the car is okay, no problems. Did the ODB II scanner reset did the job? no need to chage the sensor asap? what do you think?
Old Dec 11, 2009 | 02:16 AM
Super Moderator
I would change it - see what others think.
Old Dec 11, 2009 | 06:23 AM
Mu9enx's Avatar
01' C32o
The CPS situation was also similar for me. At first, my car only stopped starting once every 3 weeks, but as it got worse, it happened a lot more often. When it really became bothersome was when it would stop every 30 minutes. I would have to wait for the engine to cool down before it would start again, which would be about 1.5 hours. You should just change it as a pre-caution.. it isn't fun to be stranded
Old Dec 11, 2009 | 12:39 PM
victorb623's Avatar
c240
Appreciate your feedbacks/comments.
My mechanic is not available today. Will be installing it on monday. Will update you guys. I expect smoother idling and better gas milage =)
Old Dec 14, 2009 | 09:36 PM
victorb623's Avatar
c240
Part installed. The owner of the shop increased the installation fee to $95 from $35. It took them 1.5 hours. Car pulls better, smoother and hope it gonna be more fuel efficient
Old Dec 15, 2009 | 01:01 AM
samaritrey's Avatar
Super Moderator
THE C350
Awesome glad your car is back to running nice. i seriously doubt the last part though.
