M271 Cam Sensor Oil Leak
I am having them do a service A while I'm at it. $205 for the parts and labor for the Vac pump, $88 to clean up the sprayed oil mess, and $112 for the service A work. I really don't think $405 is all that bad, considering the dealership for just the service A would probably cost that much (guessing). This independent shop I'm using is great!
change while I was under the car. I thought it was the rear main seal since there are some oil between the engine and transmission housing. Brought the car in and the SA later called saying it's the vacumn pump.
Jason
