2005 C230 headlamp replacement
The best way to do this is to either have someone or yourself shine a bright flight light from the front in to the headlight assembly, then try to align the indent on the light bulb surround up and go strait in to the headlight assembly. If the rings locks with little effort and the the bulb passes the giggle test I mentioned above, you're good to go and you can immediately see the light has the correct pattern.
So you want to insert the bulb in so that the prongs are horizontal and the single indent is at 12 o'clock (precisely opposite of what the photo shows with the indent at 6 o'clock). Just GENTLY mess around with it while either wearing clean vinyl/nitrile/latex gloves and get in there. When you can easily lock the ring with only a slight resistance then you've hit jackpot. If you have to force the ring you probably didn't do it right.
BTW, have you considered upgrading to Sylvania Xtravision? They burn a tad hotter than standards so they are just a tad brighter, the trade off is a slightly reduced life but still far more life than SilverStar Ultra or the GE NightHawk Platinum. If you want the ultimate halogen go for the GE NightHawk Platinum which are noticeably brighter than SilverStar Ultra that I tested myself:
https://mbworld.org/forums/c-class-w203/328145-sylvania-silver-star-ultra-vs-ge-nighthawk-platinum.html
