running rich effects
Old Dec 22, 2009 | 12:49 PM
richardlo's Avatar
2019 c300
So my car has been running rich for the last few thousand miles. Took it to my mechanic but he kind of informed me that it would take a while to check out and usually I dont have the time to leave it there all day to pinpoint.
Drivability has been fine.
Just curious what bad side effects can result from running rich except for lower gas mileage?
Old Dec 22, 2009 | 01:19 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
running rich will kill your oem cats. OEM cats are outrageously over priced.
Old Dec 22, 2009 | 05:33 PM
Glyn M Ruck's Avatar
Super Moderator
No good for Cats or O2 sensors.
Old Dec 22, 2009 | 08:34 PM
Preet's Avatar
E63 AMG W211 & W203 Sport Pkg
How can you tell if the car is running rich?
Old Dec 23, 2009 | 03:31 PM
richardlo's Avatar
2019 c300
For me I got a code of po172 my mechanic mentioned it after hooking it up to the mercedes computer thing they do.
Old Dec 26, 2009 | 05:04 AM
tremere's Avatar
if you are running rich you probably need to replace your o2 sensors, check spark plug gap and make sure you have no fouled plugs, check your ignition coils and then make sure there is no obstructions in your air intake (change the filter) and then a throttle reset might help to...
probably a safe bet to say your o2 sensors are old though and need to be replaced... this is how your computer checks to make sure you are at optimal air fuel ratio and then balances it.
