Block Heater install (question)
My c230 does not have a block heater and I went to Weber Mercedes in Edmonton to inquire about installing a block heater. They said it will cost $600(part)+$200(labor). I also asked other shops, they generally charge $250 for everything. I don't know the difference between them. I searched the forum and it seems that others pay less than $800. Where can I order the heater online??
Do you have any recommendation if I should go with the dealer or non-dealer shops ? or do you know a good shop that can do a good job with a competitive price?
Thank you very much in advance for your reply,
Best regards,
Song
PS: the engine picture is attached,
If its an '02 or '03, it definitely has the block heater installed. All you need to do it attach a cord to connect it to the wall socket.
The pic Glyn has put up for you is the cord and all the pieces that attach it to the block heater.
Most SA's at stealerships don't know crap. Theyll tell you there is no block heater coz thye dont know..so youll have to lean on them and insist. The cord costs about $30. The block heater costs about $500. If you go and ask them to do a block heater install, theyre gonna install the $30 cord and charge you $600.
So this is exactly what goes into the plug on the engine? I'll check local mechanics about where to find this part.
Thank you jcnash,
The car is 2005 Mercedes C230 sport sedan. I'll ask local mechanics if I already have one on the engine.
Best regards,
Song
I'm thinking a pan heater or a magnet heater now, do you recommend these stuffs? Obviously I need something cheaper. Any experience on the pan heater and the magnet heater?
Thanks very much for your suggestion,
Best regards,
Song
Best regards,
Song
No experience with the other heaters....sorry.
Edmonton gets quite cold now (-17'c) and it was -46'c about 3 weeks ago. I feel so bad parking my car outside. I doubt that it will take 5 hrs too. I looked at the freeze plug and it seems that they are going to need a wench extension to unscrew the freeze plug and screw the block heater in..shouldn't take 5 hrs. I think I'll get the part and go somewhere to install it.
I'm also thinking about sticking a polar pad on the freeze plug. May work similarly to the block heater?..
Best regards,
Song
İ live in Norway (Scandinavia) have already bought the block heater kit and thought to myself just change the thermostat to start with and hey presto - engine gets warm and within 5 minutes of driving. Prior changing thermostat took almost 30 minutes to warm up.
see photo of old thermostat.
LATERS
