HID Question for Renncpe
Old Jan 30, 2002 | 10:57 AM
Bos's Avatar
Bos
2002 C230K
I just talked to hid4less to see if they've worked out the socket issue you ran into with their product. The person I talked to (don't know his name) stated he wasn't sure about this issue and suggested I go through you / Brumos as your're a hid4less wholesaler. Is this true, or can you provide any other insight about who you talked to at hid4less so I can talk to someone who knows what's going on?
Old Jan 30, 2002 | 11:04 AM
renncpe's Avatar
w203 c230K 2002
Re: HID Question for Renncpe
Yes we are set up to sell HID kits for hids4less. If you would like you can call me and I help with any questions.
1-800-434-8514
Randy
Old Jan 30, 2002 | 11:12 AM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Randy, if you don't mind, could you answer his question about the mod to the socket that you had to do here? I'm assuming that there are others here as well as me who are on the fence on this issue, and this would impact their decisions.
Thanks.
What's your price on the kit, btw?
Old Jan 30, 2002 | 11:20 AM
young's Avatar
GLB 250 4matic
heh, i just called him! randy stevens (sp?), and he very graciously answered my questions for me. he said that the relay issue wasn't addressed yet so i'm going to wait until they do. and he's convinced me that this is a DIY job. the hardest part was to remove the fender liner (which i've done before so its not a big deal).
he's going to find out about the daytime running lights issue (how is it affected?).
Old Jan 30, 2002 | 11:54 AM
Boo2's Avatar
C32 AMG
Re: Re: HID Question for Renncpe
Do you have any kit available to make the fog lamps xenon?
Old Jan 30, 2002 | 12:22 PM
renncpe's Avatar
w203 c230K 2002
Young,
There is no difference with the Xenon between daytime running and normal operation. That makes since because the is no filament whit the Xenon’s, when they are on there on.
Randy
Old Jan 30, 2002 | 12:23 PM
renncpe's Avatar
w203 c230K 2002
Young,
There is no issue with the relays they are not necessary on a 203 body car. The only snag was the connection on the wiring harness and the guy’s at hids4less are taking care of that.
Randy
Old Jan 30, 2002 | 12:28 PM
young's Avatar
GLB 250 4matic
oops, i knew that the relays weren't needed anymore. i meant that once they get the 'proper' kit together, then i'd get it. that is, the connection on the wiring harness is corrected.
<strike>do you know if the oem hids kit is a bi-level xenon kit?</strike>
also, i'm assuming that the stage 1 and 2 kits are the same except for the bulbs? i'm thinking of getting stage 1 hids and i know you got stage 2.
i contacted autoclass.net and they had sent me info that they had oem hids for the coupé about 2 months ago but in actuality, they do <b>not</b>. so the hids listed must be for the sedans at $1598.
Old Jan 30, 2002 | 11:46 PM
greg230's Avatar
black on black 2k2-230k auto/c1/c5/c7/k2c/COMAND/TELEAID/Stage II HIDS
autoclass sent me an email about 230 coupe hids back in november.... when i called about them, theyt said they didnt have em.
vapor wear i guess?
greg
Old Jan 31, 2002 | 03:42 AM
dngan's Avatar
2006 CLK280
Randy
Hey renncpe,
Do you mean that a HID retrofit kit will work on the c-coupe without the relay ? But does that mean that if we don't use the relay, we have to get MB dealers to reprogram the car to avoid the warning light issues of the on-broad computer ???
Will the HID kit work without both reprogramming and without the relay kits ?
Thanks.
Old Jan 31, 2002 | 07:28 AM
renncpe's Avatar
w203 c230K 2002
Thanks.
No you will have to use one or the other. I would recommend that you simply have the computer set to the xenon present setting. The relay kit will cost more than having the computer set.
Randy
