Tire sizes??
Old Jan 1, 2010 | 09:20 PM
FrankI's Avatar
2004 C230 Kompressor Sedan
Tire sizes??
I have a 2004, C230 Sedan, Kompressor sport. The tire websites I have visited show tire size (225/45R17 Front) and (245/40R17 Rear) as the original tires. Is this correct and if so how do you rotate the tires?
thank you!
Old Jan 1, 2010 | 09:36 PM
glocati's Avatar
2016 GLE 350
Welcome ! Those are correct tire sizes for the staggered sport set-up where the rear wheels are wider than the front. I believe 7.5" wide front 8.5" in rear. The bummer with staggered wheel set-ups is that you can not rotate them. Cheers, Greg
Old Jan 2, 2010 | 12:06 AM
ChrisRam's Avatar
2003 C320 Sport Sedan
Take the left tires and put them on the right.
Old Jan 2, 2010 | 12:17 AM
Benzben's Avatar
'05 C230K SS
As long as they're not directional...
Old Jan 2, 2010 | 07:52 AM
Glyn M Ruck's Avatar
Super Moderator
+1
Old Jan 3, 2010 | 02:31 PM
FrankI's Avatar
Tires
Currently there are 225/45R17 on both front and back. Is there a noticeable difference with 225/45R17(front) and 245/40R17(rear)?
Thanks!
Old Jan 3, 2010 | 05:21 PM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
In the middle of 2004, MB changed from 4 x 225/45-17 to the staggered setup.
If you've got an early 2004, you'll have the same setup as the '03s (all the same size).
If your tires/wheels are all the same size, then you can rotate front-to-rear. If the tires aren't unidirectional, then you can also rotate side-to-side.
If you've got the staggered setup, then you can rotate from side-to-side if the tires aren't unidirectional. If you do have unidirectional tires and you really want to rotate (as when you have severe wear on the inside corner), then you can have the tires dismounted and turned around - then you can swap the tires left/right and they'll still have the correct rotational direction.
Old Jan 5, 2010 | 02:03 AM
FrankI's Avatar
Rim/wheel size
If it does have the staggered setup does this mean the rim sizes are different
Thanks!
Old Jan 5, 2010 | 02:09 AM
acr2001's Avatar
2012 C300 4Matic
Thanks!
Yes, the rear wheels are wider than the fronts.
They are still the same diameter as the fronts though - 17".
Old Jan 5, 2010 | 11:17 AM
Super Moderator
Thanks!
7.5" front - 8.5" rear
