Replaced battery, re-synchronizing questions.
Old Jan 12, 2010 | 01:52 PM
Panzerknacker's Avatar
GL 350 Bluetec
I know, I know, look in the manual. First off before anyone gets upset I would like to start by saying I bought the car from a private owner... and he did not have the manual.
Replaced my battery after it went dead not running the car for 4 days is very cold temperatures.
So how do I re sync the one touch windows and sunroof?
Also, my passenger seat control now works backwards. Moving the switch forward makes the seat go back, switch back seat goes forward. I dont think its a bad module the battery holds its charge overnight and all. Does this need to be sync'd again as well?
Thanks in advance for anyone who takes to time to help a guy who would be happy to look in his manual if he had one.
Old Jan 12, 2010 | 04:00 PM
samaritrey's Avatar
Super Moderator
THE C350
Go to mbusa and you can download a manual for your car. since you are an army man i will help you more than that. ok windows are easy just put the window down and hold for like 5 seconds then put up holding it for the same 5 seconds. make sure when pushing button to make sure it is in the one touch mode as in clicks. as for the seats they sync the same way no idea why it is not working correctly.
Old Jan 12, 2010 | 04:37 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Similar with sunroof - get it closed and hold it for about a 10 count. It should re-synch.
Old Jan 12, 2010 | 06:08 PM
GL 350 Bluetec
Ok got the windows and the sunroof. Thanks.
Anybody have any insight as to why my passenger seat now adjusts backwards? I tried moving it fully to one position and holding then the other. No dice. I guess it is a quirk I can live with, but it kind of worries me that the module potentially may go bad and it will drain the battery.
