need help installing amp/sub
Old Mar 14, 2003 | 01:51 PM
adamrs80's Avatar
2004 SLK Special Edition
I'm installing an Infinity Basslink, and I was wondering if anybody knew the best way to get to the battery from the inside of the car. I know I'll have to go through the firewall somewhere but I'm not sure where to start. I also need to get a signal from the rear speakers (unless anybody can suggest a better way) Has anybody does this before?I've installed stuff before in a few other vehicles but nothing this nice so I don't want to screw it up. Any help would be greatly appreciated.
Old Mar 14, 2003 | 02:45 PM
firstkill's Avatar
If you have a coupe is fairly simple.
I run the power wire along the passenger side under the carpet..etc... towards the glove box. You will need to remove teh door sil to expose the carpet. Peel back the carpet from the footwell area.. (where the passengers right foot will be.) and look into that corner with a flash light. You will see a Black strip with 4 or 5 grommets in it. Remove any one of them to get access into the engine comparment ( thats the hardest part of the install ).
From the engine you can also pull out the grommet if thats easier for you. Its really easy if u remove the battery.. you will see the strip i was talking about. Or you can even see it if u move the rubber hose that drains water from the windshield.
For the sound.. I just tapped the stock subwoofer. And for the remote start up.. I ran the wire to the fusebox #7 i believe. I just got a normal fuse.. wraped the wire around it and plugged it ino. I didnt make a spade plug or anything.
~fk
Old Mar 14, 2003 | 06:00 PM
b4chow's Avatar
i found this thread helpful for wiring my car. i have a sedan and the steps are pretty much the same. most of the panels to get to the rear are removable.
https://mbworld.org/forums/showthrea...&highlight=amp
Old Mar 14, 2003 | 10:14 PM
electromethod's Avatar
Honda Grom
I just finished doing exactly the same to my C230 sedan last night. I ran 4gauge (man it was pushing it ) through the series of grommets that are located in the corner passenger side. What are you putting this in? a sedan? a coupe? It would probably serve your best interest if you post your complete information so more people will reply.
IM me if you have any questions.... since it's fresh in my mind I can tell you every detail down the last pin or even the colors for the speaker cable. I was going to do a write up this weekend and post it so the next person doesn't have a hell of at time with it like i did.
Old Mar 15, 2003 | 10:12 AM
adamrs80's Avatar
I'm doing this in a Coupe, with Bose and Command. I'm about to go run the cable from the battery, but I'm going to wait till this afternoon to tap into the rear speakers. I could use some advice on how to get the signal from the rear speakers. Do I take the signal from the connection at the speaker, at the amp, or somewhere inbetween on the speaker wire itself? thanks for your help.
Old Mar 15, 2003 | 04:00 PM
firstkill's Avatar
I tapped after teh amp before the Sub. If i remember correctly it was a purple and a brown wire. I just shaved off a bit of that wire and wrapped my amp wires to that. I didnt use a Hi/Low converter or anything and it sounds fine.
~fk
Old Mar 15, 2003 | 10:14 PM
adamrs80's Avatar
well i got it all done and the stupid thing doesn't work. I used a volt meter to test the ground, and battery connection and its all working. I've tried everything so I'm gonna send it back and get another one. thanks everybody for your advice. othe than the fact that the sub doesn't work, everything else was a success
Old Mar 15, 2003 | 10:19 PM
Honda Grom
don't feel bad... i blew the amp last night. took it apart and two of the mosfet transistors are blown. morrow i will see if i can get an ee friend to fix it for me.
Old Mar 15, 2003 | 10:23 PM
adamrs80's Avatar
the thing that sucks is that i bought it off Ebay, so now I gotta ship this 23lb Infinity Basslink back, and pay for shipping again to get the new one. sigh....
Old Mar 16, 2003 | 12:19 AM
firstkill's Avatar
Are you sure its broken???
The auto-detect Turn on doesnt work on the coupe... At least for me
YOU HAVE to use the remote turn on.
~fk
Old Mar 16, 2003 | 10:40 AM
adamrs80's Avatar
How do I use the remote turn on? I wired up the remote bass level control but I don't think that's what you're talking about. I saw a wire and screw connection for the remote turn on. I have the Command system, how do I hook this remote turn on up? Thanks for your help.
adamrs80's Avatar
Shouldn't the power light have come on anyways? Maybe I'm wrong but I figured the power light would have come on.
Old Mar 16, 2003 | 03:01 PM
firstkill's Avatar
the power light wont turn on unless something tells the sub to turn on.
There is a small thin silver wire that needs to be used for the sub to turn on.
You have to run that to the fuse box on the left side of the trunk to #7 .
THen it should turn on....when u turn the radio on and the key is turned.
~fk
Old Mar 17, 2003 | 09:25 AM
adamrs80's Avatar
I found the fuse box and number 7 but there is no fuse there. Is there a way to hard wire it up or is there something else I should do?
Old Mar 17, 2003 | 01:03 PM
firstkill's Avatar
i just wraping the wire from the amp around a standard fuse and plugged it in...
some people make a spade with it and plug it in... but i just did it the cheap way
~fk
Old Mar 17, 2003 | 01:38 PM
avlis's Avatar
2008 VW GTI
There are spare fuses tucked away with the spare tire and tool kit.
I almost bought a Basslink from Ebay too. Let me know how it sounds.
Old Mar 18, 2003 | 12:08 PM
firstkill's Avatar
It sounds good, its lound enough to rattle everything in the trunk.. including all the pastic trim pieces in the back.
The bass is soft but loud.. its not the super super low sounds from a larger sub.
Not sure how much they go on ebay..but u can get them for 280 shipped retail from an "authorized" dealer if u care.
~fk
Old Mar 18, 2003 | 11:26 PM
adamrs80's Avatar
Finally got it working. Thanks so much for everybody's help. I would have had to pay some car audio shop for something that I could do myself. For those wondering how it sounds I think it's awesome. It has so much more bass than the coupe needs. I got it for $203.00 + shipping from gr8audio on Ebay. At first when I thought it was defective, he was going to send me a new one so the guy has been real easy to deal with. If anybody is considering getting a sub I don't think there is a better way to spend about $280 which is how much it cost for the sub, shipping, amp install kit and RCA converter. It also came with a remote bass level control which I put in the lower center console so I can adjust it anytime really easily. Pretty cool.
Old Mar 19, 2003 | 07:01 PM
firstkill's Avatar
Congrats on the install... How did u mount the thing?
I ended up just using velcro I have it facing up and the back left corner.
!fk
Old Mar 19, 2003 | 07:22 PM
adamrs80's Avatar
I put on the legs, but I haven't mounted it yet. I was actually planning on using velcro. Right now its right by the bose amp in the rear facing upward. Sounds pretty awesome.
Old Mar 20, 2003 | 07:31 AM
avlis's Avatar
2008 VW GTI
Why did you need an RCA converter? I thought Basslink had speaker level inputs?
Old Mar 20, 2003 | 12:38 PM
firstkill's Avatar
it does... the only thing u need extra from a basslink is
1 fuse/ fuse holder for the power. The power cable, and a ground cable.
The rest comes with basslink
~fk
Old Mar 20, 2003 | 01:59 PM
adamrs80's Avatar
What I used to install the basslink was an amp install kit, and an Adjustable line output converter, which I tapped into the Bose sub's wires, and then ran the RCA's from the line output converter to the basslink. There may by other ways to do it but I was told that this was the best way. Seems to work great so I can't argue.
